what are the diffences between a normal and cosworth saph
01-10-2007, 07:49 AM
Shell?
im going to look at a cat c write off cossie later but it was written off in 1992. i want to see if the shell is still genuine. is there anyway of telling the 2 shells apart.
where there any diffrences between the 2 shells
many thanks
mike
01-10-2007, 08:08 AM
not 100% sure but I thought the gearbox bracket holes were different (this may be for a 3dr shell only though)
someone will be able to confirm.
01-10-2007, 08:14 AM
*** Sierra RS Custard ***
3 door only, and they are only different upto B reg, after that the tunnels are the same.
01-10-2007, 01:37 PM
thanks
would i be right in thinking one shell for all then??
01-10-2007, 01:42 PM
Yoon
The shell for the Saph Cossie is the same as all Saph shells IIRC. Think they have a load of holes for brackets etc on the inner wings because of that above reason.
01-10-2007, 01:44 PM
Cossie shells also had reinforced A frame pillars. Lesser models didnt.
01-10-2007, 01:55 PM
Quote:
Is that just the saphs?
As my 500 and 1.6 shells appeared the same in this area.
01-10-2007, 01:59 PM
yip
01-10-2007, 02:03 PM
You learn something new every day!
I wonder why they particuarly choose there to re-enforce though, doesnt seem an area that needs attention to me!
01-10-2007, 02:06 PM
dunno why either, but know they did. They were foam filled and reinforced.
a golden nugget for ya
01-10-2007, 02:10 PM
01-10-2007, 02:18 PM
You sure they were foam filled mate, cos they have drainage tubes running down inside them?
01-10-2007, 02:25 PM
No1 Blower.
I am sure the cosworth Chassis numbers started differently to the normal sierra, WFO is it as the cossies ere all german made???
jdsjojo
30-08-2015 07:48 PM
Marc sierra
12
30-08-2015 10:38 AM
lukeeboy149
22-08-2015 04:29 PM
155lee
14-08-2015 11:21 AM
14-08-2015 07:29 AM
