saph cos 4*4 spongy brakes
spongy brake pedal
if i hit the pedal hard brakes lock on.
but a slow press some times the pedal just slowly sinks down. and i lose the bite unless i hit the pedal again.
the cars has goodridge stainless braided brake hoses 6 piece kit
Front brakes:
AP Racing 4-Pot Calipers with 330mm grooved AP discs
Rear brakes:
305mm vented disk conversion
Ferrodo Ds2500 pads all round
no apparent loss of brake fluid anywhere![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
ideas
Front brakes:
Rear brakes:
ideas
it would appear so robbie
i was going to change the pads last sunday.then remembered had no copper grease for back of the pads.and all the motor factors where shut by 3pm
as the front calipers have two bleed nipples on each pair. is there a preferance which one inside or out to bleed first
I never use copper grease on the back of the pads, or the sepertately supplied anti rattle shims, I have yet to have any noise at all from them either.
It does sound like air in there still, I never bother on any car with order as I personally have never found it made any difference at all.
