Turning off ABS
Turning off ABS
i know some cossie boys fit a switch to cut the power to the ABS pump on their cossies, but can this be done to other cars?
im gonna be using the wifes puma for a track car hopefully soon, and gonna fit some esc cos brakes etc, coilovers and get a miltek exhaust...
but the ABS will get on my tits on a track day, so will want to turn it of off poss?
what wires do you cut?
ta
ta
DONT unplug or disconnect the ABS Pump........On the cossie this supplies the brake boosting pressure(Like a servo) the correct way to stop a cossie ABS is simply to cut one of the fluid level wires on the cap(the one with the square plug that clips on securely)this disables the ABS without switching off the pump and losing all of your brake pressure....
Guest
Posts: n/a
Originally Posted by NEEDFORSPEED
does on a cossie but doesnt on pumas does it? i stand to be corrected if it does!
Will investigate further....
thought so, ye just unplug anything so the ecu sees a fauld and puts the light on which in turn disables the abs, may have to take the bulb out tho if you can or if its an led put a bit of tape over it or it will get on your nerves!!!
Originally Posted by Dan@FastFord
Dave ZS - do you mean disconnect the plug by the rear beam for the rear sensors?
cheers all
