10 Year olds maths homework - Can anyone on here do it?
Here you go!
Using the digits 0 to 9, once each only, make five different numbers that:
Assignment 1) divide by 7
Assignment 2) are prime
Good Luck!
CheeRS
Good Luck!
CheeRS
Originally Posted by xxx
Quite enjoyed that challenge:
1) 7 28 35 84 91 all divide by 7
2) 2 3 5 7 61 all prime
correct?
correct?
There's no 6 in your first set of answers, plus I think you need to use the zero too.
Originally Posted by AX Cossie
7,49,28, 56, 301
thats the 5 divided by 7 using all the digits 0-9
Thanks!
Did you have any sort of method?
I think kids must be a lot smarter then they used to be look at this thread:
https://passionford.com/forum/viewtopic.php?t=291813
Makes me wonder how I got my degree! I wouldn't even get into secondary school now!
nah just trial and error guessed the first few then figured one of the numbers must be a 3 digit and a Maths degree helps!
Ill leave the prime numbers to you guys!
Re: 10 Year olds maths homework - Can anyone on here do it?
Originally Posted by M7 COS
Here you go!
Good Luck!
CheeRS
Good Luck!
CheeRS
The question cannot use all the numbers to answer both assignments - it aint possible, as you will need more numbers than provided to do both assignments as such it is surely just...
Prime numbers - 1, 2, 3, 5, 7
Divisible by 7 - 0, 7, 14 , 28, 63
My best guess, based on the sketchy wording of the question
JJ
Originally Posted by JjCoDeX75
Where does it say that you have to use all the numbers?
JJ
JJ
I think you're supposed to use all the numbers 0-9 for assignment one and then again all the numbers from 0-9 for assignment two.
Wow - that is a tough question for a 10 year old then!
Bugger that. I think I will stick with the far easier Quantum Physics! I have just worked out what Quarks are!!!
