Best road going spec based on a GT30
#81
So how much maintenance does solid lifters need, and how hard are they to set up in the first place?
Also, Martin you state that it feels different up to 8k on solids. Would this be noticeable on a lesser spec such as mine? (32psi peak 28psi hold on std comp engine T34 0.63).
I only ask because I will be taking my engine out again at xmas time, and I thought about putting solid lifters in last time, and decided against at the last minute. Second chance city!
JJ
JJ
#83
*** Sierra RS Custard ***
JJ
JJ
Not hard to do at all providing you bite the bullet and just buy a big bucket full of different size shims to swap about
Cams out job of course!
Wether you notice the difference a lot or not is largely about cam profile, the more aggressive the cam the more the hydrualics fail to follow it, so on your spec I personally wouldnt even consider solids TBH as I dont think they will benefit you enough.
#84
Testing the future
i only know from bike engines that rev high and use solid lifters that the clearances have to be measured and shims correctly fitted at fairly regular intervals, but it all depends on material specs, cam profiles, spring rates, oil etc
although on my vfr750 the engine is so well built that it hasn't needed any adjustment in 50,000 miles
#85
although on my vfr750 the engine is so well built that it hasn't needed any adjustment in 50,000 miles![Top](https://passionford.com/forum/images/smilies/smile011.gif)
50,000 miles at 12,000rpm +
So imagine how long you can potentially get away with on 8Krpm, lol
honda specify 50K service interval on the ITR iirc
#86
Testing the future
Originally Posted by martin-reyland
It's an easy job to do and should not be a consideration.
#87
#88
Maintaining valve clearances would not be problem for me.
The outlay that Franco mentioned (£400-£600) would not put me off either if it were worth it on specifically on the type of build that I have mentioned.
#89
Originally Posted by Chip-3Door
Solid lifters really arent that needed, you can see 8Krpm on the hydraulics.
For a budget build I wouldnt bother as its money that could be spent elsewhere.
#90
#91
how long till yours is all done now then??
#92
1st to 200 without NOS
#93
Not rushing mate being honest, but want it finshed and mapped for the Ring trip at Easter!
Too much personal stuff happening at the moment (not bad stuff) so it'll get finished when I can spare it the time.
PM sent dude!
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
PM sent dude!
#94
i sometimes wish i hadnt bought my T34.48 now. I really fancy going same route as Andy. Might get a GT30 now too. What manifold do you have to run? and can you use it on std internals, with std cams?
#95
Standard cams will be "ok" but it would be worth putting in a BD12 or BD14 inlet really.
Head needs porting really
Std internals for the bottom end will be ok, but potentially can limit the torque compared to a reduced CR (although not if you go to mr shead it would seem
#99
Originally Posted by Mark Shead
Originally Posted by RWD_cossie_wil
Talk about secret squirrel
On a different tack, I will be running a CR Engineering T38 on my escort cos, looking for anything around 420BHP, but I was hoping for a nice fat midrange but I am a bit worried now
I also have a GT35 sat under my bench, now a few people have swapped back to the GT30 from this, is the general opinion that a GT35 is a bit too big for a 2.0 YB to be nice to drive on the road?
Mark
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
SMILER258
28-09-2015 09:04 AM
