Best road going spec based on a GT30
Old 24-09-2007, 05:31 PM
  #41
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
got a mate who's gt4 runs a gt3076r and 8.5:1... and he's thinking of making it higher comp! had no problems whatsoever so far at 1.1 bar
mine (on a gt3076r or gt3082r will be roughly 7.8:1 when finished hopefully
Old 24-09-2007, 05:42 PM
  #42
Red16
Red16's Avatar
go both ways eh Mark also pm sent
MD Cos thats exactly my point
Old 24-09-2007, 05:49 PM
  #43
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
is it not just how different engines are designed..????
Old 24-09-2007, 06:22 PM
  #44
marco polo
marco polo's Avatar
Franco
you having internal or external
Old 24-09-2007, 06:48 PM
  #45
lead_foot
is awesome
lead_foot's Avatar
Sales of GT30's have sky-rocketed!
Jump on the bandwagon, Yee Haa!!!!
Old 24-09-2007, 06:57 PM
  #46
Red16
Red16's Avatar
dunno, not trying to stir things up, just always wondered when reading car specs.
Old 24-09-2007, 07:03 PM
  #47
Stavros
DEYTUKURJERBS
Stavros's Avatar
What do you fucking expect at only 1.1bar FFS
Originally Posted by Red16
the jap lads all seem to run around 8.5:1 generally.
Not many of them at that compression run over 1.5bar on pump fuel though. Might run 2bar+ on race gas etc on track etc tho.
And a LOT of people bullshit about what comp a car is. I know for a fact some big name Skyline tuners run comp in the mid 7s and keep it quiet or blatantly lie.
And standard compression pistons DONT always mean standard compression
And you can run more boost, but less ign, and ign generally gives more power than boost after a certain level.
And you can also get away with more with wilder cams, more headwork, and bigger exhaust housings.
And all that lot is exactly why engines need to be specced as a whole, as pic some bits of a low comp engine, and some of a high, and you will end up with a properly shit engine.
Old 24-09-2007, 07:09 PM
  #48
Mark Shead
Mark Shead's Avatar
I run 8.5-1 on the Evo's with a GT35 running 2.5bar boost on pump fuel.
Mark
Old 24-09-2007, 07:11 PM
  #49
Mark Shead
Mark Shead's Avatar
Stavros
Also I am just doing a Evo with a GT40 and above 8.5-1 on pump.
Mark
Old 24-09-2007, 07:16 PM
  #50
Red16
Red16's Avatar
but 8.5:1 compression pistons should mean 8.5:1 comp pistons surely!
i know what youre saying Stavros but theyres just far too many jap cars (more than a few on the MLR) running this kind of c/r with say 1.5-2bar boost on pump fuel, they cant all be lying.
Edited to say - isn't Gary@APT running 1.8bar and 8.5:1 with fantastic results?
Old 24-09-2007, 07:19 PM
  #51
_DAN_
Yoon
_DAN_'s Avatar
Doesn't the skim of the head change the situation there?
Old 24-09-2007, 07:25 PM
  #52
rapidcossie
rapidcossie's Avatar
The comp ratio on my car is so low that people on here would say it must be shit, yet is one of the most powerful and responsive like for like.
Old 24-09-2007, 07:32 PM
  #53
Red16
Red16's Avatar
yeah it makes the comp ratio higher
Old 24-09-2007, 07:34 PM
  #54
Stavros
DEYTUKURJERBS
Stavros's Avatar
Enlarged combustion chambers
And yeah, im not saying they all lying, they not, not even a majority of them, im just giving the various reasons.
Also engine/head/piston design plays a part, just like the cams/turbo/etc i already mentioned.
Skyline GTR engines, and maybe Evos too, can run a shocking amount of ignition compared to what cossies seem to be able to.
Infact GTR engine it seems, if ran at ign numbers you would normally consider normal and safe, are shite and run dissapointing numbers.
There more than one way to do anything.
Old 24-09-2007, 07:43 PM
  #55
Red16
Red16's Avatar
yeah thats true, never thought of enlarging the combustion chamber... but lots run standard heads so that would eliminate that.
this is more at what i was trying to get at, but i guess its not a simple one line answer as to why this is the case
Old 24-09-2007, 08:15 PM
  #56
NEIL A
NEIL A's Avatar
Must all be to do with the fact the whole engine has been speced to work with the low comp. Im sure that Neil from Carwise was on something stupidly low aswell like 6.8:1 and it went well too
Old 24-09-2007, 09:36 PM
  #57
Franco
Franco's Avatar
Originally Posted by marco polo
Franco
Going external route now Marco, as thats what Martin has said will suit the build
Cant bloody wait!
Old 24-09-2007, 09:41 PM
  #58
rapidcossie
aint 6.8 high comp?
Old 24-09-2007, 09:49 PM
  #59
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
I wouldn't run high compression on a car that is going to be regularly maxed out or see track days UNLESS you have the budget to run suitable fuel at these events.
What you classing as high comp Mike?
everytime i see a cossie spec its always got low comp, between 6.8 and 7.*:1 whereas the jap lads all seem to run around 8.5:1 generally.
What difference does it make if theyre both ran on say Shell V-Power? How come it works on Evo's etc but not on cossies, even though they both run decent boost levels?
I understand the theory behind detonation but the 8.5:1 compression doesnt seem to cause any problems over on the darkside, but scares the shit out of the ford boys
You can't compare differently configured engines. The Evos run a much smaller bore size than the Cossies, and the smaller the bore, the higher the compression you can run.
Old 24-09-2007, 09:51 PM
  #60
Chip
*** Sierra RS Custard ***
Chip's Avatar
The evo cylinder head shape also appears to be a little better for avoiding detonation too.
Old 24-09-2007, 10:34 PM
  #61
RWD_cossie_wil
RWD_cossie_wil's Avatar
We do this topic every 6 months, all we ever get is Sheady going 8.1-15.1 , Rainbum going anything over 8.1 is a timebomb , and lots of from people, why even bother replying if you are not going to tell us what you are running?
Talk about secret squirrel
On a different tack, I will be running a CR Engineering T38 on my escort cos, looking for anything around 420BHP, but I was hoping for a nice fat midrange but I am a bit worried now . Engine will be 7.4:1 (cc'd) , with a std exhaust cam and a BD14 inlet, with mild headwork, having spoke to my tuner I have every confidence his prediction of not a lot more lag than a .48 T34 will be true, as the engine has been specced with this turbo in mind. If I don't like it I might be forced to try a GT30
I also have a GT35 sat under my bench, now a few people have swapped back to the GT30 from this, is the general opinion that a GT35 is a bit too big for a 2.0 YB to be nice to drive on the road?
Old 24-09-2007, 10:35 PM
  #62
Chip
Chip's Avatar
QUOTE OF THE MONTH!
Old 24-09-2007, 10:46 PM
  #63
MAD Ade
MAD Ade's Avatar
Will be interested to see what mine's like on the road. The new manifold has transformed the power from the GT35, can't wait
Old 25-09-2007, 03:31 AM
  #64
Porkie
Porkie's Avatar
Franco
Cant bloody wait!
solid lifters now bastard!
Old 25-09-2007, 05:12 AM
  #65
Mark Shead
Mark Shead's Avatar
I would easly run stock compression on that spec or above, I have a stock engine running a ported head maxing out 560cc injectors running 2.1bar boost and that version turbo works very well on it.
Mark
Old 25-09-2007, 05:53 AM
  #66
marco polo
marco polo's Avatar
Franco
Cant bloody wait!
oh cool
Old 25-09-2007, 06:56 AM
  #67
Franco
Franco's Avatar
Porkie
YOU READ MY MIND! Oh well that'll cheer Martin up no doubt!
marco polo
All this fucking around trying to decide on what turbo to run Marco, just seemed easier to fork out a little bit more and go external!
Old 25-09-2007, 07:25 AM
  #68
Mike Rainbird
Caraholic
Mark
Mark,
What sort of ignition values does the Autronic allow you to run at that kind of compression? The only reason I don't (and AVA) like high compression, is the reduction in ignition you have to run to compensate for the high compression. On a heavily used track car, the heat this puts into the engine is immense, so the benefits of high compression are negated by the resultant down-side of the ignition being retarded compared to where it could be with a lower compression. Personally, I would rather run the engine cooler with us much ignition advance as I could have and loads of boost, rather than loads of boost and lots of retard (by comparison) to compensate.
Low compression allows you to run 16-20 degrees on the top line, where if the compression is too high, this can be reduced to single figures....
Old 25-09-2007, 07:38 AM
  #69
rsnissan
rsnissan's Avatar
Thanks for the replies, quite a lot to digest.........................
Loving Doug's post that Porkie quoted, that's pretty much the stomping ground I was after with the build. Although on more of a tighter budget I'd guess
RE the solid lifters, is it worth fitting these in a relatively standard build? I am guessing this will allow for higher RPM but what else would you require for this?
Franco what is the rest of your spec I would got for an external gate as well while I was at it so yours sounds interesting
Old 25-09-2007, 07:41 AM
  #70
Chip
Chip's Avatar
Solid lifters really arent that needed, you can see 8Krpm on the hydraulics.
For a budget build I wouldnt bother as its money that could be spent elsewhere.
Old 25-09-2007, 08:02 AM
  #71
Franco
Franco's Avatar
rsnissan
Reyland endurance spec Andy! <---- Just for big will
I'll Pm you all the spec mate, got it somewhere...
Old 25-09-2007, 08:10 AM
  #72
Franco
Franco's Avatar
So in essence Chip I'd be getting approx 600-900rpm for an outlay of say Ł400-Ł600 smackers?! (new cam, lifters, shims etc)......
Old 25-09-2007, 08:12 AM
  #73
Chip
Chip's Avatar
You can rev to 8000+ on the hydrualics.
Revving too 9000 instead would have me wanting to change the conrods as well personally, so I disagree with the figures you are mentioning when applied to a nearly standard engine like the one this thread is about.
Old 25-09-2007, 08:13 AM
  #74
Martin-Hadland
1st to 200 without NOS
Martin-Hadland's Avatar
You can see 8k on hyd and I have done this in the past but believe me the engine feels completely different on solids at that sort of rpm.
Like you said if it's budget build then maybe not worth it but it is worth doing at the time of engine build rather than thinking about carrying out the conversion at a later date. So what I'm saying Mr Franco is if we are doing it let's do it NOW not after it's fitted into the car.
Old 25-09-2007, 08:18 AM
  #75
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Mark is making mine higher compression after the development work on the Dyno. mine was 7.4:1. Im not technical but im sure Mark will say what was going on.
It runs unristricted boost 2.5bar all the way .
Was on Hydraulic lifters @ was rev'ed to 8.3k regularily including pulling 8.3k in 5th (210.2mph). Its now on solid lifters just in case we have the Power to pull past 8.3 in 5th which is 218mph on my present gearing.
Old 25-09-2007, 08:19 AM
  #76
Chip
Chip's Avatar
Martin, on hydraulics you of course run the risk of losing valve lift at the most important time, high RPM, so I totally agree with you that they are worth doing in a big spec build, was only for this application (cheapy cheapy) that I was saying the limited budget available would be better spent elsewhere (like a decent rear diff for example)
Old 25-09-2007, 08:20 AM
  #77
Chip
Chip's Avatar
At 8.3K I suspect you were losing power due to the hydraulics, as I reckon the valves were no longer following the desired profile.
  #78
foreigneRS
Testing the future
foreigneRS's Avatar
don't forget that solid lifters will require maintenance as well to maintain valve clearances whereas hydraulic don't
Old 25-09-2007, 08:22 AM
  #79
Chip
Chip's Avatar
At regular use of 8K rpm and just above, I would argue that it is in fact the other way around!
Old 25-09-2007, 08:28 AM
  #80
Martin-Hadland
100% true, I know that from experience.
Quick Reply: Best road going spec based on a GT30
