562BHP - MANY THANKS TO NMS ;)
Old 24-09-2007, 05:12 AM
  #41
Dingy
Dingy's Avatar
Thanks for the comments...
As for the boost, there are other reasons to why its capped to
The Boost map is not 100% finished, we are trying different things to see how it feels.
Looks like the thrust bearing has gone in the turbo, so this could explain why it appears a bit lazy and doesn't come on boost as early...
We will get that sorted and see what it makes in a couple of weeks
Old 24-09-2007, 05:16 AM
  #42
cossie4i+
TT T38 Power
cossie4i+'s Avatar
It will be interesting to see how the car does at Torque of the Devil
Awesome power Steve
Steve.
Old 24-09-2007, 08:55 AM
  #43
Neil@FastFord
Neil@FastFord's Avatar
Heard about this at weekend!
Well done pal, that's just plain sick!!
Old 24-09-2007, 09:04 AM
  #44
RichardPON
RichardPON's Avatar
I didn't know you could get boost control that altered with gear changes....
Surely you knew that?
Mike had different boost levels for different gears in his saff 10 years ago, using a slightly crude but very effective set of electronic triggers on the gearlever.
Bet the car goes well though - I haven't been out in it since it had no arches, greens and a T34, and was held together with cable ties!
Old 24-09-2007, 09:07 AM
  #45
Linsay
Linsay's Avatar
It's still held together by cable ties
Just kidding ding - it did you proud at weekend, looking forward to Brands in it now
  #46
Lambchop
PF Idiot Sniper
Lambchop's Avatar
same here
i was in it the day before it blew up and was off the road forever
think it was after a rr day actually. maybe the PTS luton one?
Old 24-09-2007, 12:37 PM
  #47
Dingy
Dingy's Avatar
Did it work though ?
Old 24-09-2007, 12:38 PM
  #48
Dingy
Dingy's Avatar
And yours is by the ironoxide
Old 24-09-2007, 12:41 PM
  #49
Stavros
DEYTUKURJERBS
Stavros's Avatar
Look at all the excited young men Mike took for a ride in his car.
It worked for Mike
Old 24-09-2007, 12:48 PM
  #50
Linsay
Linsay's Avatar
and cables ties
Old 24-09-2007, 01:57 PM
  #51
Dingy
Dingy's Avatar
and cables ties
You'd best take some spares to brands LOL.....
Big FOOOKERS
Old 24-09-2007, 02:14 PM
  #52
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Crude? It had a microprocessor and combined with the micro switches on the gear lever, you could tell it which boost position (0-9) you wanted it to have in each of the five gears. Worked with the air injectors, and I actually had it usually set so that it could do 2.5 bar of boost in the lower gears and then 2.2 bar in 4th and 5th . This was for show boating with the tall diff:
235/40 tyres:
1st = 59mph @ 8000rpm
2nd = 89mph @ 8000rpm
3rd = 129mph @ 8000rpm
4th = 172mph @8000rpm (my favourite party track, getting the shift lights flashing at 170mph and then changing UP - you'd hear a wimper from most people ).
5th = 216mph @ 8000rpm (most ever seen in fifth = 6800rpm).
0= 0.7 bar
1= 0.9 bar
2= 1.1 bar
3= 1.3 bar
4= 1.5 bar
5= 1.7 bar
6= 1.9 bar
7= 2.1 bar
8= 2.3 bar
9= 2.5 bar
Anyone of those settings could be programmed into any gear .
Old 29-09-2007, 01:19 PM
  #53
Fagin
Fagin's Avatar
Good figures Steve!
Forget the power figures..... it´s how it drives that counts. As you said if you can not fully get the power down (regardless of what that is) with your set-up, whats the point in having the torque at that rpm. Some people seem to forget you have 2wd and fuckall weight! Of course plemty others will say they have that power, but if the car losses traction there is NO point in having that power at that rpm.
As said.... definately worth having per gear boost control. Get a proper ECU (like a standard Scooby one lol) and you can have ignition, boost & fuel per gear! Of course other aftermarket ones are available that you can use.
Old 29-09-2007, 01:46 PM
  #54
RichardPON
RichardPON's Avatar
I only said crude by today's standards!
It was 10 years ago don't forget...... old man!
Old 29-09-2007, 03:11 PM
  #55
Chip
*** Sierra RS Custard ***
Chip's Avatar
External boost control on the L8 would be ok, but the real gains to be had would be with moving onto something like Autronic, that would totally transform that car
Old 29-09-2007, 03:53 PM
  #56
Dingy
Dingy's Avatar
why would autronic transform the car.
The L8 was designed with the cosworth the autronic will run different pot engines won't it.
I'll still with the L8 cause the autronic car's have have been in don't seem any smoother on and off the throttle LOL...
Old 29-09-2007, 04:40 PM
  #57
Tom Baxter
Tom Baxter's Avatar
Awsome car Dingy and you can drive it mate its always nice to watch you at a track day. I will look forward to seeing the car in action at Brands.
Is there any chance of taking my 17 year old son out in Kia it would be awesome for him he is always going on about your car and he fancies a trip around Brands in a proper car.
Old 29-09-2007, 04:49 PM
  #58
Chip
Chip's Avatar
Because you would be able to use features like traction control and boost control in gears to allow you to have back that 150lbft you have lost (and more)
The L1/L6/L8 series of ECU's wasnt designed for the cosworth, it was used on loads of different engines, its just what ford could get hold of cheap a couple of decades ago that was up to the job compared to other ecu's of that time.
You probably need to go in some more cars with SM2/SM4 etc fitted then to see the benefits.
Old 29-09-2007, 04:56 PM
  #59
Jay,
Sponsor
Jay,'s Avatar
the webber is a lancia or ducati or fiat ect ect ect oh then cosworth iirc
Old 29-09-2007, 05:00 PM
  #60
Chip
Chip's Avatar
Exactly, the only thing "matched" to the cossie is the standard map that we all throw in the bin anyway as its running bugger all boost and bugger all advance, lol
Old 29-09-2007, 06:13 PM
  #61
Deleted by Request
Former Sponsor
Deleted by Request's Avatar
...my ducati 916sp runs the P8 as std!
...not too fused about aftermarket ecu's tbh...L8 up is more than adequate!
Old 29-09-2007, 06:55 PM
  #62
Chip
Chip's Avatar
On a fantastic engine like the one Karl has built dingy, it would be nice to have some boost control (either from the ecu or externally) that is more than just "adequete", it would be good to have something that means he can have the massive torque the engine is capable of producing at the times it has traction for it, and then still make it tame like it is now (relatively, its still an animal im sure, lol) in the lower gears.
Old 29-09-2007, 09:52 PM
  #63
Dingy
Dingy's Avatar
staffi's engine made less torque on autronic from the autronic upgrade LOL
and the ONLY reason i would never buy autronic in the uk cause i'd have to give mark money LOL....NO THANKS.....
Old 30-09-2007, 12:35 AM
  #64
Gregs
Gregs's Avatar
top result dingy, shame there was no mag there to feature it
maybe there will be one there next april when you try again??
think you should go for 627 bhp now, same as the mac F1!!!
Old 30-09-2007, 08:35 AM
  #65
cressy
cressy's Avatar
your son would never forgive you if he went out it kia
Old 30-09-2007, 09:58 AM
  #66
Tom Baxter
Tom Baxter's Avatar
Hi mate how are ya doing is Dingys car that mental then I know its one of my lads favourites and I trust Steve after watching him on numerous occasions. Better bring some spare trousers for him then. I dont think Ding as seen the thread any chance you can ask him for me mate.
Old 30-09-2007, 11:47 AM
  #67
RS500
RS500's Avatar
This will fly.
Oldschool whit new school power rocks.
I think 500+hp is plenty for a ford escort mk2 escort.
Old 30-09-2007, 12:18 PM
  #68
Stu.H
Stu.H's Avatar
When is the NOS being fitted steve?
Old 03-10-2007, 12:35 PM
  #69
Mike Rainbird
Caraholic
Personally I think it would be wrong to try and get the lost torque back, as it would still be undriveable and would be an accident waiting to happen even in the taller gears.
I totally agree with how Steve has had it mapped, as now he can drive it HARD without having to worry that the car is going to bite him big time, which will make it MUCH faster on track.
Old 03-10-2007, 12:41 PM
  #70
JonnyBravo
JonnyBravo's Avatar
I'm starting to believe a Apexi AVCR is the way forward tbh, you really need to know how get the most from it though or its worthless.
Properly awesome though Dingy and I agree with Mike that you can most probably drive it harder and safer now
Old 06-10-2007, 06:28 PM
  #71
scoooby slayer
scoooby slayer's Avatar
is this the same mk 2 that made 420 hp today ?
Old 06-10-2007, 06:44 PM
  #72
rapidcossie
rapidcossie's Avatar
420 ATW?
Old 07-10-2007, 10:46 AM
  #73
scoooby slayer
id be interested to know what happened with this car ? made 560 last week and 420 this week
was it not running right yesterday or lost some boost or something ?
Old 07-10-2007, 11:28 AM
  #74
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
Old 07-10-2007, 11:34 AM
  #75
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Went out in it yesterday - Fuck figures! Its fucking shifts!
Old 07-10-2007, 11:36 AM
  #76
Christian and Beccy
#1 in Spelling Club
There is no way on gods green earth would I get in that. Numbers aside, 400/500/600hp or whatever the fuck it is, I bet its a missile.
Old 07-10-2007, 11:39 AM
  #77
Charlie Chalk
Unknown.
It is mate....
  #78
Dingy
Dingy's Avatar
One run made 420 @ fly then 400 then 450
Old 07-10-2007, 11:41 AM
  #79
Dingy
Dingy's Avatar
Is it cause its not laggy and has loads of midrange
Not a can of worms, as the figures were all over the place on my runs and it ran less boost i'll take it with a pinch of salt...
  #80
Dingy
Dingy's Avatar
It is mate....
Glad you enjoyed it
Quick Reply: 562BHP - MANY THANKS TO NMS ;)
