Gearbox options
#88
Originally Posted by NEIL A
Didnt Andy G say he would like to test one of these dog boxes Marco, would be good to see it tested under full race conditions.
Hi Neil
yes he did , im not sure what ratios he uses in his R+D tho or his rear diff ratio
if he use 3.9 in the rear and a 3.6 on the front we have to change the step off gears ,the gears that we are be using are standard ratio this might slow his car down a bit
we could always lend him one to try ill have a word
porkie has just broke his fix it box thats why i said about the dog box for him
marco
#91
Originally Posted by Porkie
Another BIG problem is that you can select any gear and any time.....
You CAN very easily Buzz an engine with a Dog box.
Martin, Sean, Wes and a think Kev sharp all buzzed engines with dog boxes....
The chances of me not doing it are slim to none
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
#92
Former Sponsor
#94
Originally Posted by Cosworth Rallyesport
what box are you going to convert to sequential then?
I have a skyline gearbox, fitted with a Pfitzner dog engagement gearkit, there is a company called Ikeya Formula in Japan that sells an adapter that bolts into the gearbox and makes it sequential, i think Simon Norris used this bit of kit on his last Evo to convert a Hollinger box.
#95
Hi Neil
marco
fix it gearbox broke
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
wonder when the parts will be available.
#96
#97
Former Sponsor
ive seen them on evos.look to be a good conversion,dont think it can be done with mt75 though as its one rod that changes where as these are twin cables.
#99
i can think of a electrical machanical setup that might work! have the movement controlled by a microprocessor and you would have paddle shift
#100
Hi Neil
marco
Hi dave
i think he might have just broke the OE 1st gear
he told me launched it from a juction and heard a funny noise might not be to bad
bara's got a few uprated 1st gears if he wants it or he can just wait 12 weeks for the dog box
marco
#102
Former Sponsor
#103
#104
#105
Bara could easy do a MT75 sequential it would cost alot of money and i don't think it would sell well as you would have to have loads of different gear ratios options for it
The FFD is a H parttern Dog box it can be coverted to sequential but it's mega money to do
Im sure Bara has done stuff for Simon N orris through Tal motorsport
marco
#107
marco polo
thought there was not meant to be any real stress on the first gear,hence not fitting an uprated gear.
well there is alot less stress on the 1st gear as the 4th uprated gear takes most of the load but that still doesn't stop them from breaking but does help
marco
#109
marco
Its the cost involved in the design, casting, machining that push the price up.....i'm saving up for mine ATM
The FFD with sequential then brings it some where near an xtrac....
Once the sequential and gear cut are done, the leap to paddle shift aint that expensive....
Quaife do or did a sequntial MT75....and they were just as awful as every other MT75 dog box they did....
#111
Caraholic
Dave,
Even the guy with the 750bhp Cossie in Sweden breaks first gears and main shafts (the standard Ford items), which even Dangerous has broken in launching on the Bara kit. If Lee is lucky, this will all it will be. Hopefully it hasn't taken out anything else
Not sequential, but a conversion kit for the MT75. Not sure how the syncros will fair...
![](https://img.photobucket.com/albums/0703/MikeR/Quickshift01.jpg)
![](https://img.photobucket.com/albums/0703/MikeR/Quickshift02.jpg)
![](https://img.photobucket.com/albums/0703/MikeR/Quickshift03.jpg)
#114
i sat down today and thought a little more about it!
a paddle shift gearbox would be easy enough to make
![Raz](https://passionford.com/forum/images/smilies/tongue.gif)
![007](https://passionford.com/forum/images/smilies/bond.gif)
yes
EDIT<, i dont know why the link wont work,,
#117
#118
i think the best way, is to use two stepper motors, and a mirco controller, would be much easyer, and could make it alot more programable so speeds of shifts
#119
Testing the future
didn't the transits come with a 2wd mt75 box that had a paddle shift option that was basically some sort of pnuematic actuation of the h-pattern shift?
#120
my method would work on a standard MT75 with standard gear selector shaft
