EECIV ECUs for ST Cossies
Old Sep 20, 2007 | 02:49 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Default EECIV ECUs for ST Cossies
Providing these have the same ECU code, can they be swapped between cars or is the PATS system an issue?
Old Sep 20, 2007 | 03:56 PM
The Youth.'s Avatar
The Youth.
Mike, my small turbo doesn't have the pats system, it has the wipac immobiliser fitted, I presume most of the early small turbos will be the same so it's a case of finding an eary st ecu.
steve
Old Sep 20, 2007 | 04:03 PM
Mike Rainbird
Caraholic
Does the code tell you anything? Basically I have a COSY ECU and want to know if it will work on another car that also has a COSY ECU - mine is a 1996 car with the red key?
Probably a question for Stu, so I will PM him the link .
Old Sep 20, 2007 | 04:06 PM
The Youth.'s Avatar
The Youth.
Mike I think there are about 4 different 4 digit codes for the st, honestly don't know if they are interchangerble or not, presume the same codes will be if the key is then programmed in by a "key shop"
steve
Old Sep 20, 2007 | 04:49 PM
ECOS95's Avatar
ECOS95
I have tried to swap mine with a friends of the same year 1995, not sure if the ECU code was the same but it was having none of it.
Old Sep 20, 2007 | 06:40 PM
Mike Rainbird
Caraholic
I know the ECU code has to be the same, so just need comfirmation about the pats. Have PM'd Stu, so hopefully he will shed some light on the subject .
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
cossie330
Sep 27, 2015 04:13 PM
Russ Payne
Sep 25, 2015 08:29 PM
Steve Cooper
Sep 15, 2015 04:39 PM
