zetec into a mk4 help
iv done this and if ya use the 2.0l ya need to change the fly wheel sump sump pick up pipe i used a engine mount off a mk4 escort and nipped the corner off it so it fits as for the loom i couldnt make it work so i put a dta on it
oh and as above as the sump goes the other way to the 2.0l so need new manifold
me and my mate done a couple zetec conversions pretty simple we found the 1.8 better [cheaper] you can use some early engine loom ecu [none key code] have run a 2i with standard loom ecu just a few simple mods were needed. good luck
mk3ste
17-10-2021 10:09 AM
SMILER258
28-09-2015 09:04 AM
