Missfire underload when warm
Old Oct 1, 2004 | 09:51 PM
cossie1's Avatar
cossie1
Default Missfire underload when warm
Right as of last night my R19 16v runabout shit box has started to missfire.
When started from cold it's fine will run fine, responsive etc, as soon as it's upto normal running temp it develops a slight miss, which then gets worse and worse and then it starts to kangaroo a bit and looses almost all acceleration, even if I hold foot flat to the floor it will miss right upto the limiter (i know this ain't the best thing to do, but I was seeing if it would pull through the miss, at first it will but after a while it won't just miss's constantly).
Just seems weird it only does it when upto normal running temp
any ideas ???
anyone ?
cheers
Old Oct 1, 2004 | 10:42 PM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Phase1 or 2?
them bonnet vents let water right ontop of no.1/2 plugs/leads.
change them first matey.
if not then check fuel pressure and the throttle position switch (if its got one, cant remember)
Old Oct 1, 2004 | 10:44 PM
cossie1's Avatar
cossie1
phase 1
it has loads of silicon (or something similar) around the under side of the scoop already
I did take the cover off earlier and leads 1 and 2 were dry but slightly loose, I pressed them down again until they clicked, but still the same.
Old Oct 2, 2004 | 12:15 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Dizzy cap/Rotor arm.....if its kangarooing badly sounds like spark to all 4 plugs i crap or bearly their?
cossie362
Oct 11, 2015 03:53 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
pabloXR
Sep 21, 2015 12:42 PM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
