Comp Ratio Question.
Old Sep 9, 2007 | 01:46 PM
Nash's Avatar
Nash
Cake lover!
Default Comp Ratio Question.
As above got a question regarding my Comp Ratio.
I built my engine to 7.5:1 comp. We then decided to use a thicker Cometic multi layer head gasket instead of a Grp A, which dropped it lower again. Car was mapped a few weeks ago by Ahmed and at my request mapped Safe as i will give the car lots of abuse.
The problem i have now is the Cometic Gasket has started to pressurise the system[like many others], now i want to just fit a Grp A instead as never had a problem with these. I know its going to raise the comp and bring it back up to 7.5:1. What i want to know is does it need to go for another session of mapping or will it be alright?
Cheers Nash.
Old Sep 9, 2007 | 01:48 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
You could fit two gaskets
Old Sep 9, 2007 | 01:50 PM
JonnyBravo's Avatar
JonnyBravo
Changing the c/r is going to require a remap imo
Old Sep 9, 2007 | 01:55 PM
Nash's Avatar
Nash
Cake lover!
Just wanted to know. I did tell Ahmed it was 7.5:1 and not any lower but i will ring him and ask. My mate has a set of Det Cans and an LM1 so might get him to check it first.
Old Sep 9, 2007 | 01:57 PM
JonnyBravo's Avatar
JonnyBravo
That would save you a trip back to Ahmed.
It very well might be ok, I'm no mapper but its certainly cheaper to get looked at than replace an engine
Old Sep 9, 2007 | 02:00 PM
ECU Monitor Enthusiast
Fit the gasket and have it DET checked by a proffesional.
CR changes of this magnitude will only affect spark advance requirements
and fuelling will be ok.
You can take 2 degrees out of the map by linking the ignition retard pins
on the ecu which isnt ideal but will get you back on track.
ANy loss on ignition retard will be made up with the CR increase.
I doubt it will have an effect anyway as most tuners allow a safety margin.
Old Sep 9, 2007 | 02:02 PM
JonnyBravo's Avatar
JonnyBravo
You say get it DET checked by a professional Simon but tbh you can hear DET well enough on my mates car with the cans on so I cant see why you can't check that yourself.
Obviously Nash can't personally do anything about it but he would know its not right
Old Sep 9, 2007 | 02:03 PM
Nash's Avatar
Nash
Cake lover!
Yeah my mate knows what he si doing. I Have a way i can chage the values on the the chip, so could take sound out of the ignition if it was detting. If its needs doing i will probably just take it back to Ahmed to sort tbh as like Jonny says its cheaper.
Prickly_buzz
Dec 7, 2017 09:52 PM
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Karl @ FPT
Sep 21, 2015 11:17 AM
Bransby
Sep 11, 2015 01:09 AM
