ERST and FRST turbo oil drain?
Where does the turbo oil drain go on a ERST and FRST? Is it returned back into the block or the sump and where abouts?
Has anyone got any pictures that show it?
Lukesville
Originally Posted by jonesymk2
would it matter if the return went into the sump atall if i welded a pipe onto the sump
As long as the fitting is above the line of oil i cant see why not.
I must be damn luck then as I've never replaced my rubber pipe on my S2 and I've owned the car for 11 years. Each time it's been off I'v einspected it and everytime it's gone back on. Damage on these hoses is usually down to people swinging on jubilee clips rather than using the proper spring clips.
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
