Bonnet raisers
#41
STOP!... Carry on
Originally Posted by DaBoy12s
Originally Posted by tabetha
You only get a vortex where there is a trailing edge such as on a wing profile.
i think what she was on about, is that the "vortex" created actually pushes air down behind the engine, rather than up and out...
#42
surely the venturi principal states that the air travelling at speed over the bonnet and over the gap will draw air out of the engine bay. #if the air hit the windscreen and changed direction it wouldn't go into the bonnet due to the high speed air traveling above it, so surely an eddy would be caused.
#43
STOP!... Carry on
#44
Raising the rear edge of bonnet in almost all cases does cause a reduction in water temp, this is because you are allowing more air to exit the underbonnet area, principle been the more air you let out means more air can be let in so more can pass through the rad.
The trade off is higher drag.
Simon.
Simon.
#45
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
07-10-2015 12:56 PM
Adam Graham
06-09-2015 06:04 AM
