Croft......whos ready & whos panicing then???
Well mine is virtually done - spare engine fitted & running at the weekend.
All I've got to do is an oil change & an MOT for the weekend!!!
I've just about finished a re-build of my Mi16 engine - few bits left waiting to arrive though
Engine to fit and all ancillaries and then run in..... Fingers crossed it'll be there on Saturday morning ready to go!
Chop.....yeah its been sat for 2 years outside!!!! Cant you even get down for one day???
Paul - Naah mate.....my coated rings & steel liners didnt arrive in time so couldnt build my blingy one - so only running 15/16psi on this one - should hopefully be ok for the weekend anyway........stops well now with my APs fitted too......
Yeah.....the quaddie!!! Buckets in, brakes fitted, bigger turbo exhaust housing fitted - no surge - looking more like a track toy now!!!
2wd....still awaiting bushes!!!
Dave.....I'm sure it will be done - you've got a fighting chance if you've got all week off - gonna try to get down to JCs tomorrow for MOT!!!
I mentionned your issue to Dingy & he said it could be a bad earth & to ...
....thats if you havent already! LOL!
Originally Posted by EltonJohnLookalike
check the wire from pin 32 to the injector and see if its being pulled to earth with the ecu disconnected
Using your NEW (lol) multimeter, using the 'Ohms' setting check the continuity between pin 32 & an earth!!!
Here ya go if you are stuck...
http://www.acmehowto.com/howto/homem...inuitytest.php
how the fook do i check that,not got a clue.
my track car is nearly done, it needs:
new discs and pads on the front
a brake fluid change
fuel pipe securing under the car
and a wash it's still covered in mud from my donnington off!
my escort needs,
fuel filter changing
osf out cv joint
then I'm ready, I'm using both on track so hopefully both will be ready...
off to get the discs now
steve
my escort needs,
osf out cv joint
steve
