T4 or GT30 which one would be better? Discuss Please
Running a T34 with mar m shaft as I run (quite aggressive) antilag and want to keep it.
Contemplating upgrading my turbo to one of the above as even my tuner says that the turbo is too small
Would I be better off getting hold of a T4 with a mar m shaft or getting a GT30.
I think remember Mike Rainbird saying on a previous thread that the T4 flowed more air etc than the GT30 hence him sticking with the T4 on his car.
Please discuss as this interests me to see what the pro's and cons are.
This is on a zetec not a cossie lump.
Many thanks,
Dave
Many thanks,
Dave
I've heard alot said about the GT series turbos being brittle but i think it's myth alot of it, ok 1 or 2 have failed and when they do it's in the bin time, but T4`s fail too.
The Jap lads run alot of GTseries turbos and i don't hear them having much trouble.
Your choice i guess and only you can decide..
I'm having a GT30 later this year so hopefully it'll be fine..KISS OF DEATH..
DEYTUKURJERBS
Originally Posted by miller3
Originally Posted by JTECHSAFF
The GT series doesnt like ALS does it
i know of tons of cars running ALS and no DV on GT series turbos.
thing is most of the jap cars run lower boost then us, hence why they dont fail over there as much as here. thats the same reason this influx of cheap shit turbos is on ebay, the jap guys can get away with them, but they dont like 40psi
I know Kev Atkins runs over 2 bar on his, don't think he's had many issues, Mark is the man to tell us really..
Mark
Mark
Mark
No i havent Steve' So sway me over to the DARK side
Mark
Mark
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
I believe the GT series turbos are more succeptable to bearing failure through prolonged use of ALS/Launch Control than a 360 bearing based equivalent. I know this is the case on smaller framed GT series for definite.
(Having smashed a GT28RS to bits with ALS)
Not to mention the thinner shafts on the GTs...
i changed from a t34 running agressive ALS on my 1600cvh to HYBRID GT30 and it was like driving a different car,
it spools up so much quicker than the t34 and does not require the help of the anti lag, although i do still run mild ALS and i dont run a dump valve and never have,
good enough to run a 12.6 second quarter so im happy
I dont know much about strength of GT turbos mate.
I only know about T4 turbos as thats what I have ran for nearly two years.
Someone give me a GT30 and ill test it for them
Originally Posted by Paul Ripley
Dave I would have thought your T34 would have been capable of producing more then 310bhp on a ZT, is it deffinatly the turbo thats holding you back?
Originally Posted by Big Will 85
Oh - and you can get 500bhp with a GT3076 on the larger AR turbine housing
sorry I never got a chance for more than a hello at Nat day
Euan, where does your T4 come in at??
My T38 kicks in around 3800...
I bet that's a handfull in the wet then.. or DRY...
It does sometime catch you out in the wet.
Wheel spins on about half throttle in 4th
Will wheel spin in 5th if you let the boost come right in too.
Wheel spins in 3rd in the dry too
This is with 235 F1's too
A proper rear set up is needed at this power level but its too expensive
Going to have the rear shimmed up to try to it on the cheap.
