Oil cooler hose sizes....???
What size is recommended for a Stage 3 Cossie setup using an air to oil cooler???
The Rad I have has 1/2" Bsp connections but my existing system uses 5/8".
I accept that 5/8" is probably the best option, but I want to use a Stat so am stuck as to how to connect the 1/2" Bsp cooler to the existing 5/8".....
Ive looked to see if anyone makes a hose connection that screws onto the 1/2" but which then has a hosetail that fits 5/8" hose but no luck so far........
Failing that ive looked for a female 1/2" Bsp to female 5/8" adaptor but no luck there yet either...........
Ive also emailed the likes of Mocal and not had a response.
Hoping somebody on here as sufficient experience of Oil cooler systems to be able to help.
Has the cooler got fixed fittings?
On my first cossie, I ran a 5/8 setup, with remote filter and stat.
Might have to look at selling it if there's no other way around it.
Right, think Ive solved it............
Apparently I can get a Thermostat that is like a sandwich plate, which can go between the filter and housing on the remote filter housing.
This has 2x outlets which can straight to the Oil cooler.
£7 for 2x aluminium weld on 5/8" Bsp fittings, and then i'll be able to use 5/8" hose and fittings...........
