Still having problsm HELP!!!
As i posedt before the 3 door wouldnt start, got the crank pick up sensor and fitted it tonight and it started ok but when driving it if you drive easy it is fine.
If you boot it and it gets to about 4500RPM on boost it just cuts out, sometimes back fires and the red engine warning light comes on.
Then notice the oil was leaking from the coil so changed that but it hasnt solved the cutting out problem?
Any help would be great
Thanks
Thanks
