piston rings or turbo?
Originally Posted by mechanic28
well imo if it was piston rings u would have smoke on and off boost!sounds like turbo to me
but then i thought as the cylinders are being pressurised by the boost i thought that it could be the rings that have gone
but im more towards the turbo now will take it off and send it back for inspection on wednesday then
Former Sponsor
Originally Posted by dave green
turbo can be checked simplely by checking up and down movement on the inlet fan of the turbo
Dave
Dave
play in the shaft wont make it smoke
smoke is the oil getting past the rear seal and into exhaust system
will be under warranty then?
if it has, then the turbo should be right, and id look elsewhere first before sending it for inspection
Not sure then mate, my mates old engine was cunted thanks to someone on here but then there's not alot you can do about that, 'meant' to be a 6k block! My ass!
Did NO miles though and it still took the turbo with it!
You live and learn though hey!
Former Sponsor
how many miles has it done exactly since rebuild, and how long have you been driving it at a time....
it COULD just be oil in the ex system from last turbo if it was badly smoking before...
take it for a long run and see if it sorts itself out..
carl
carl
compression is 140 across all cylinders so i know the compression is ok but this doesnt show oil rings as i need a leak down test to do this and i havnt got the Ł60 at the mo to have it done
i was driving the car about i took the engine out of and just replaced the headgasket on it and bought some new stuff
carl
carl
the orinal car was std rite down to teh exhaust and was running a t3
alls ive done is fitted a grp a gasket and put this new turbo on
i bleed the turbo up before firing the engine up, and ran itin for about 80 miles as i wanted to get used to the car again
after this the fuelling was checked and set and the boost increased to 25psi
couple of days later it started smoking really bad
and is just getting worse, ive done an oil change aswell and still no difference, breathers arnt block and everything is faultless bar this smoke,
and its costing me an arm and a leg in oil
Former Sponsor
then get it sent off for inspection, they will see straight away if its been leaking past rear seal
why its split, get them to fit a staggered rear seal
will help no end
will help no end
ok
my spec is
std 4wd cos engine
grp a gasket
spec-r grp a breather system
t35..63 exhaust housing
rs 500 intercooler
turbo coller
samco hoses everwhere
bosch 044 fuel pump, new filter aswell
mongoos exahust
k+n induction cone filter
green 803s
3 bar map sensor
level 8 ecu
the spec is ver reasonable and was the same spec as my last engine
tis engine has been running std all its life until i put it in my car
, it ran 15psi for running things in , then was put up to 25psi
my spec is
std 4wd cos engine
grp a gasket
rs 500 intercooler
turbo coller
mongoos exahust
green 803s
3 bar map sensor
level 8 ecu
I've just had exatly the same problem... fine on start up, fine on light loads, and normal driving. As soon as it's on boost huge clouds of smoke...
and only after i fitted a new bigger turbo..
I checked the turbo and all was well..
Then i pulled the head off and found nothing unusual..
Then i pulled the bottom end apart and found no.3 three oil control ring was broken.. And this was on an engine that had apparently just been rebuilt...
Hope yours isn't as expensive a job to repair!
Could well be rings mate, I hope for your sake its not though
My mates is nearly as bad as that and he changed his turbo and it made no difference.
Atleast you can have your turbo inspected for nout though
JonnyBravo
i do hope to god it is
its like that on over run aswell but disapperas
car is fine when not on boost, just starts to smoke when the turbo is just kicking in
if its not the turbo then im sure i can sort something out regarding an engine rebuild, and may aswell go more power or at least build it for more power for a later date
Originally Posted by xr4x4rs
ok little update
its not the turbo, this is in perfect condition
so now im looking at rings, or valv guides
if not any of them i havnt got a clue
