Big up to Doug Stirling
For letting me have a drive of his escort cosworth last night.
What a fantastic engine that is, its real credit to Doug with the choices he has made and of course to all the people like Karl and Martin who have put it all together for him.
Very cool car indeed
Thanks for letting me have the chance to take it out
I must say a big thanks to Doug aswell, bought some of his new parts off him for my Saph, parts arrived this morning and I only sent the cheque off friday!
Excellent service and a pleasure to deal with!
Dont know him but he must have been mad to drive through the crowd in Yeovil sat night when the bars were evacuated!
I was cringing someone was gonna hit the car,, riots vans turned up later lol
Thanks Chip.
I like other people to drive the Es Cos from time to time so as to get some feedback about how it go's and feels on the road.
Thanks for all for the kind words posted by others too
What is the final spec Doug?. I know you had a fair bit of work done between Karl and Brom, but didn't know Martin also had a hand in it.......
From memory it should be up there or close to Yum, is that correct?
1994 Escort Cosworth in radiant red, "L8 ECU"..............here is the specification:
Engine:
Reyland built YB 2 litre on 200 block, WRC gasket, 7.2:1 comp ratio, cosworth racing pistons.
Nick Waple head with additional work by Karl at NMS (3 angle valve seats), solid lifters = 8,200 RPM rev limit (soft cut), 8,500 hard cut limiter.
Somerset stainless steel plenum, 1000 cc MSD / Rochester injectors.
5 BAR MAP sensor.
Coilpacks, cam trigger.
Reyland supplied Garrett GT30 turbo with .86 exhaust housing.
Turbo Smart 46mm external wastegate, Reyland screamer pipe.
Pro Alloy intercooler.
Water injection (disconnected at the moment).
3" Mongoose exhaust system.
Ryan Pestell custom engine loom.
Level 8 ECU with MSD coilpack conversion.
Live mapped by Karl Norris: set at 2.4 BAR spike, 2.1 BAR held to the limiter. (has actually been mapped to 2.6 BAR)
Transmission:
Mullet gearbox built by Bara Sing.
Quaife ATB front & rear diffs.
Uprated 60nm centre diff.
3.62: 1 final gearing.
Reyland supplied/fitted AP 6 paddle clutch with hydraulic activation.
Suspension:
Ahmed springs/Koni dampers
ZOO beam - improved/modified by Reyland.
Mike R geometry settings.
Brakes:
AP 4 pots/330mm front with DS-2500 pads, standard brakes on the rear with R & B "apex" pads
Wheels:
8 x 18" Super T's usually.........sometimes Comp Mo's 8 x 18" (15 mm offset).
Originally Posted by L8 ECU
Ryan Prestall custom engine loom
Football Cwazy
Originally Posted by xr-stu
Originally Posted by St3V3_C
Cool. But how did you end up L8, not P8?
All Escorts were P8 until they went to the dodgy Ford thing on the small turbo.
Football Cwazy
im not on about what ecu it came with, i mean the car was originally an L reg car, so putting a P reg plate on it isnt aloud
you should explain yourself better then!!!
Indyrs
04-12-2022 12:39 PM
SMILER258
28-09-2015 09:04 AM
