engine bay pics
Old Aug 17, 2007 | 09:43 PM
jawanne's Avatar
jawanne
Default engine bay pics
hi i need pics of s2 engine bay as i need to no wher....which breather and boost pipes goes tany info would be help full .thanks
Old Aug 17, 2007 | 09:50 PM
jayjay's Avatar
jayjay
hope this helps pall
Old Aug 17, 2007 | 09:55 PM
jawanne's Avatar
jawanne
cheers mate do you no where the pipe goes from the turbine on the turbo does it go to the metering box and which one goes to the botom of the inter cooler thanks
Old Aug 18, 2007 | 01:00 AM
xr4x4rs's Avatar
xr4x4rs
the bottom outlet on the turbo snail goes to bottom of intercooler
the compressor bit goes to metering unit
and top intercooler goes to crossover pipe
Old Aug 18, 2007 | 02:26 PM
jawanne's Avatar
jawanne
hi thanks mate that how av done so its right the only thing now is water pipes and breather pipes as i only have ones for the other engine that i took out and tht was a 3i
Old Aug 18, 2007 | 02:42 PM
xr4x4rs's Avatar
xr4x4rs
breather is almost the same
passenger side rocker cover goes to crank at bottom at back of block
then drivers side you have the breather filter mushroom type thing
specific to rst
it goes to rocker cover, vac pipe to top of inlet, then a long black plastic pipe that goes round to metering unit
water pipes are exactly the same as a 3i, only difference is the top rad pipe ha an extra pipe coming off for turbo cooling and the turbo water return which goes to the middle lug on the rad
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
JoeyBoyden
Aug 18, 2015 10:52 PM
track.focus'd
Aug 12, 2015 05:53 PM
