Closed loop
Old Aug 11, 2007 | 07:09 PM
Matt Baxter's Avatar
Matt Baxter
Back in black!
Default Closed loop
what sort of cost is involved and can/is it diy fit also what sort of mpg does it give(is it worth the outlay)
i put in £35 and got 150 miles with a bit of motorway(not booting it much ) to/from work and the light was back on
or would i be better off getting a diesel runabout
Old Aug 11, 2007 | 08:29 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
all you need to have is a L8 ecu from a 4x4 saff, make sure it has the relevant tps sensor, and a chip to run your spec.
the lambda wires to pin 2 of the ecu, feed the sensor with a live and earth from the wiper motor job done.
all in it is fantastic, engines will last longer, oil stays clean for longer no borewash etc... on a run i have seen 38mpg....but i was driving very very carefully, mixed driving i average at about 28-30mpg.
Old Aug 11, 2007 | 08:35 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Do you only get good MPG when it rains then??? LOL!!!
Old Aug 11, 2007 | 08:38 PM
Mark 3D's Avatar
Mark 3D
Moderator
how much does it cost then?
Old Aug 11, 2007 | 08:44 PM
JTECH James
Passion for Fords!
coont
Old Aug 11, 2007 | 08:45 PM
JTECH James
Passion for Fords!
well depending on engine spec chips are around £250, do you have an L8 ecu? if not they are £150 ish if you cvan get hold of one, the sensor is £75 ish
Old Aug 11, 2007 | 08:48 PM
Mark 3D's Avatar
Mark 3D
Moderator
I have an L8 with Pectel management.
Im not sure what you mean about the sensor?
Old Aug 11, 2007 | 08:52 PM
JTECH James
Passion for Fords!
the lambda sensor that needs a boss welding into the front pipe ,unless your car is a 92> model then you will already have one
and stu can do closed loop chips for pectel boards now i thonk ,where as before you would have had to find a standard board
Old Aug 11, 2007 | 08:53 PM
Matt Baxter
Back in black!
lambda sensor it sits in the exhaust
edit i am so slow to reply
Old Aug 11, 2007 | 08:57 PM
Mark 3D's Avatar
Mark 3D
Moderator
That clears that up then!!
cant afford to have it done at the moment but i might consider it in the future!!
that or LPG!! lol
Old Aug 11, 2007 | 10:07 PM
Jasesapphy's Avatar
Jasesapphy
i pulled 38-40 to the gallon up to ford fair, on the way back with an 140mph fly past still managed about 35 .
There and back, less than a tank of fuel and over 300 miles
Old Aug 12, 2007 | 07:30 AM
I get 26 average, 34(50ish) is best on a run, WITHOUT CLOSED LOOP.
CL much better though, just need to get hold of L8ECU man on here but have not seen him posting for a while.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
pabloXR
Sep 21, 2015 12:42 PM
tib2220
Sep 14, 2015 12:33 PM
