Ohhhhhhh bugger EDITED NOW WITH PIC
11-08-2007, 11:03 AM
My 2wd is now NO wheel drive, pulled away at some lights (really gentle i might add) and i heard a clonk and now i aint got any gears
Steve.
11-08-2007, 11:09 AM
diff gone....
11-08-2007, 11:10 AM
Sounds from the front Dave but havent really investigated yet
Steve.
11-08-2007, 11:13 AM
Sounds nasty
2 wheel drive boxes don't normally break do they?
Magenta one? Prob diff gone..
11-08-2007, 11:14 AM
must be the lay shaft in the gearbox.
prop not snapped ...
11-08-2007, 11:15 AM
Quote:
thats the thing with the magenta ones.
found why pics in a mo
Steve.
11-08-2007, 11:16 AM
pmsl yeah bloody magenta ones
Wont be first time diff went. Cant imagine box though.... easy way to know which what i dont was put it in first great and get out of the car with engine running
11-08-2007, 11:18 AM
Rhys
shoud have had a proper diff in your car Rhys.
11-08-2007, 11:20 AM
How the hell has that happened.
Steve.
11-08-2007, 11:22 AM
WTF they look like they have just come out? HAs its taken of the threads in the diff?
Is it only on the one side? If so check the other side!
11-08-2007, 11:23 AM
That's odd
I've not seen that before
Also whats the brown bit, by the bradied line?
11-08-2007, 11:25 AM
Not yet checked the threads just stuck my head under and thats wot i found. will find out more later as going to a party .
Steve.
11-08-2007, 11:26 AM
Fuel pipe m8.
Steve.
11-08-2007, 11:29 AM
there looks tobe lots of iron fillings etc...around that area imo, the bolts may have been moving about for a while and then just come out.
have to check the threads Steve.
11-08-2007, 11:30 AM
looking at the bolts too, they look like they have part of the threads on them.
maybe the pics....there crap.
Kin hell
11-08-2007, 11:31 AM
Will do Dave, will make sure they torque up to the correct tightness.
Still looks to be a cheap fix, thought i was looking at taking the box out
Steve.
11-08-2007, 11:33 AM
think th box may have been easer lol.
may need the diff off to sort it if the threads have gone.
11-08-2007, 11:35 AM
Just looked at the threads on the bolts and they look clean,
The shaft they bolt to on the diff, is this easy to remove with diff in place.
Steve.
11-08-2007, 11:41 AM
its quite common for the bolts to come loose
i had this on most of the sierras ive had and always check them every month just to be safe
at least it happened as you pulled off and not at speeds
should be a cheap fix mate if the threads are intact
you can take teh diff out in situ but its a bitch if the top bolts have seized
11-08-2007, 11:45 AM
Moonstone Steve
why remove the shaft Steve.
just pull the bolts out and put them back in using locktite.
I find it amazing how all the bolts could work loose and then still be in the driveshaft, oh well will investigate more later on.
Steve.
11-08-2007, 11:46 AM
Quote:
Moonstone Steve
Was on about if the threads have gone on the bit that the bolts attach to m8.
Steve.
11-08-2007, 12:15 PM
If the flange is fucked i think i have some at work Steve
11-08-2007, 03:30 PM
TT T38 Power
11-08-2007, 06:33 PM
Quote:
Thanks m8 will let you know if i need one,
Steve.
11-08-2007, 06:34 PM
Quote:
Originally Posted by cossie4i
Just a minor set back m8, least not stranded at the pod with a blown diff
Steve.
11-08-2007, 07:11 PM
TT T38 Power
Quote:
Steve.
Bitch
Are the threads ok ?
Steve.
11-08-2007, 07:22 PM
Resident Wrestling Legend
bolt it back up again
if the threads are fooked you can just pull the back plate off the diff and pull the pin to release the stub shaft
11-08-2007, 07:49 PM
Steve.
Bitch
Steve.
Not had chance to have a look today but will first thing tomorrow.
Steve.
11-08-2007, 11:10 PM
i imagine expensive and very messy
lucky man
12-08-2007, 08:42 AM
Team HOTHOT!
lucky man
Its not that bad actually, I had one go on the motorway at 70mph on an XR4x4 - some of the bolts had worked loose and the remaining 2 sheared off with a night loud bang
12-08-2007, 10:49 AM
lucky man
70mph & Loud bang =
12-08-2007, 11:06 AM
Just to update, no damage done to threads, all back together now ready for ND
Steve.
12-08-2007, 11:25 AM
Nice one Steve.. All bolts ok ? I have these also if you want to change any buddy.
12-08-2007, 11:36 AM
sounds like a diff to me
12-08-2007, 12:39 PM
TT T38 Power
Well done Steve
Bit of luck mate.
Well the fuel pump is all rewired on my car now, had 11.3v at the pump when i started and now have 13.26v
Also fitted my GrpA coil at long last.
Steve.
