help needed,whats this called?
need some help please
my air con fan on the bmw has stopped working
getting power to the fan but it isna`t spinning,on stripping down there is this 10 of these connectors
![](https://i35.photobucket.com/albums/d163/banhambuilt/fanconnector.jpg)
the main motor plugs into the connector and the connector is held in a plastic sleeve and push`s onto a copper wire.
it is roughly a 5mm male connector and the bottom hole that push`s onto the copper wire is roughly a 1mm slot.
anyone know where i might be able to get some from or even what they are called?
tried google but can only find normal push on connectors.
thanks for your help
dave
dave
it is a spade connector of sorts but it locates a copper wire at the bottom in a plastic sleeve and a female connector from above above,can`t really attach a seperate wire instead of this as motor will be spinning very very close to it,can`t be sure wire wont catch
