Oil Sump bolt Stuck!
Old 04-08-2007, 12:09 PM
lukeytheduke
lukeytheduke's Avatar
Default Oil Sump bolt Stuck!
HI folks, in the middle of an oil change for my run around fiesta 1.3i N reg. However its bloody stuck and the nut is starting to round off, any other way of draining the oil?
My mechanic said he's done loads of these in the last couple of years, and that the only way to do it is to weld on a 22' or 24' nut then it comes of easy. but i cant book it in till next week.
Today is my only day of so any other method of getting it done today would be very handyy
Luke
Old 04-08-2007, 12:11 PM
Graceland
Team HOTHOT!
Graceland's Avatar
Normal sump nut size = 13mm socker
Easy way to do it - get a 12mm 12 sided socket and bray it onto the nut, the force of hitting the socket on will shock the plug to help release tension and the 12mm socket will grip it admirably for you to undo it
Old 04-08-2007, 12:16 PM
ECU Monitor Enthusiast
If all else fails, weld another nut/bolt to it.
I had to do this once
Old 04-08-2007, 12:19 PM
lukeytheduke
what do u mean by bray it on mate?
Old 04-08-2007, 12:20 PM
lukeytheduke
p.s only got a hexagon set
Old 04-08-2007, 12:23 PM
Graceland
Team HOTHOT!
Graceland's Avatar
Bray it on = smack it on with a big hammer
a hexagon set?
Old 04-08-2007, 12:25 PM
haz87
haz87's Avatar
hexagon - 5 sided socket i imagine
Old 04-08-2007, 12:26 PM
Gary F
Gary F's Avatar
[quote="Graceland"]Bray it on = smach it on with a big hammer
Old 04-08-2007, 12:27 PM
Graceland
Team HOTHOT!
Graceland's Avatar
Never seen one of them before
Old 04-08-2007, 12:28 PM
haz87
haz87's Avatar
ok so maybe its 6 sided
lukeytheduke
just a set iu got from halfrauds a few years back, not cheap but not top of the range
i dont understand northern slang mate
Old 04-08-2007, 12:29 PM
Graceland
Team HOTHOT!
Graceland's Avatar
Do you understand this:
Get a smaller socket, smack the cunt with a hammer over the plug head and then use a ratchet to unbolt it
Old 04-08-2007, 12:31 PM
lukeytheduke
whats a cunt??
Old 04-08-2007, 12:32 PM
lukeytheduke
its only jacked up, i tried hammering it but you just look like a retard as you cant swing the hammer at all
haz87
haz87's Avatar
jack it up higher
Old 04-08-2007, 12:33 PM
Graceland
Team HOTHOT!
Graceland's Avatar
Go from a differnt angle then or get it higher baby, higher
Old 04-08-2007, 12:37 PM
lukeytheduke
how can i get it higher mate!?if i jack it up anymore it wall fall of
Graceland
Team HOTHOT!
Graceland's Avatar
Axle stands, bigger jack?
Do you not have the propper tools boy?
Old 04-08-2007, 12:39 PM
haz87
haz87's Avatar
Or if you dont have a torch take the engine for a long fast run to get the sump warmed up. Then give it a shot... just dont get boiling hot oil all over you
lukeytheduke
Originally Posted by Matt J
cant believe the 6 sided socket is slipping
I've had them undo allsorts of dodgy stuff, never successfully smashed a smaller socket onto anything either
Get a torch and warm it up (not a maglite ) and try again with the socket.
i heard its best to it when its cold
Old 04-08-2007, 12:44 PM
James
James's Avatar
ffs i can't believe theres such a long thread on how to remove a sump plug!
Old 04-08-2007, 12:45 PM
lukeytheduke
best to take the sump plug off COLD! ? !
yer im not to sure why buts its harder to get of hot than
cold
Old 04-08-2007, 12:46 PM
haz87
haz87's Avatar
Just heat it up
Old 04-08-2007, 12:54 PM
StephenC
..BS Motorsport..
StephenC's Avatar
if you were near me you could borrow my liquid extractor, its a small bore tube that goes down the dipstick holder and vacuums the oil out into its receiver.
http://www.screwfix.com/app/sfd/cat/...21663&ts=94167
Old 04-08-2007, 01:00 PM
lukeytheduke
is it easy to use mate?
Old 04-08-2007, 01:06 PM
StephenC
..BS Motorsport..
StephenC's Avatar
piece of piss, push the hose to the bottom of the sump pan, put the hand pump into the reciever, give it about 20 pumps to get the vacuum going then leave it 10 minutes, come back to a receiver full of oil and empty engine. Cant see any downside really and I know alot of garages use them on newer cars (albeit more proffesional air operated versions) to save jacking up and removing sump plug and having to replace gasket and plug.
Old 04-08-2007, 01:36 PM
James998
James998's Avatar
Arent ford sump plugs 1/2 inch and not 13mm, but everybody uses 13mm spanners because this is the 21st century?
And theres no such thing as a 'stuck' sump plug, you're just not strong enough :P
Old 04-08-2007, 04:09 PM
bluescortcossie
bluescortcossie's Avatar
yer im not to sure why buts its harder to get of hot than cold
probably something to do with different types of metal , the plug prob expands more than the sump making it tighter in the threads
Old 04-08-2007, 04:13 PM
Eagle
Super Moderator
Eagle's Avatar
6 sided socket is always better than multi splined ones...
Old 04-08-2007, 05:58 PM
James998
James998's Avatar
I think he meant it's better to drail hot oil than cold oil.
Not for removing the sump plug.
Old 04-08-2007, 06:28 PM
StephenC
..BS Motorsport..
StephenC's Avatar
last time I did it with the oil hot it flew out quicker than I expected and got litres of it all over the road cold is best IMO
Old 04-08-2007, 08:19 PM
carfixz
carfixz's Avatar
Ditto
Smart fortwo bottom brake caliper nut is 5 sided
Quick Reply: Oil Sump bolt Stuck!
