inlet plenum help please
Old Aug 2, 2007 | 05:50 PM
Dicko&Vacant's Avatar
Dicko&Vacant
Default inlet plenum help please
right ive just fitted a 4x4 inlet plenum fuel rail and pressure reg to my 2wd saff but used the 2wd throttle body etc (dont know if different)
The car runs fine but has got what seems like an air leak now, sort of like a loud whistle it goes away when you rev the car.
i even removed the full thing and put more new gaskets on but still the same
can anybody shed any light please
Old Aug 2, 2007 | 07:37 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Default Re: inlet plenum help please
You want to do a pressure test next me thinks.
Pump the hoses with air (compressor and bung in the inlet pipe) Spray soapy water everywhere round the plenum - look for bubbles. Fix leak, Bob's your uncle.
Si
Old Aug 2, 2007 | 07:39 PM
rapidcossie's Avatar
rapidcossie
why did you change the plenum mate?
Old Aug 2, 2007 | 07:43 PM
Dicko&Vacant
was told a 4x4 one is better than a 2wd :cool can flow more air etc
Old Aug 2, 2007 | 07:49 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
favorite is the two bolts through the throttle cable bracket leak air
Old Aug 2, 2007 | 08:08 PM
Dicko&Vacant
cheers ill have a look
Old Aug 2, 2007 | 10:29 PM
Dicko&Vacant
anyone else?
Old Aug 3, 2007 | 07:17 AM
Get yourself a can of WD40, spray all around the joints, when the stuff gets sucked in it will give white smoke, and increase idle a little, just a lot easier.
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Chopshop85
Sep 12, 2015 06:42 PM
