s1 boost/running problems
Old Aug 1, 2007 | 08:14 AM
cressy's Avatar
cressy
Default s1 boost/running problems
my s1 will not boost properly it`s got a bleed valve on it{which i hate}no matter which way i turn it the boost does`nt change just stays at half a bar i`v taken the plugs out which were black as fook .i`v only had the car 2 months it came with a graph showing it was running 1.7 bar and 198 bhp i`v not changed anything on the engine at all all help/advice appreciated
Old Aug 1, 2007 | 12:22 PM
davidreader5's Avatar
davidreader5
Default s1 boost
Hi, Sounds like the wastgate control is stuck, when the engine is cold
see if you can move the wastegate linkage with the actuator rod,
you should be able to feel it move and spring back aginst your movement.
sounds like its stuck open,, actuator or wastegate, you may also have a weak boost pipe letting out air,
check all hose's to and from the turbo inc the intercooler and to the inlet
manifold, if a vacuum leak is present Rs turbo mfi, usually run rough or cut out on idle.
Regards Dave R.
Old Aug 1, 2007 | 12:44 PM
cressy's Avatar
cressy
thanks for that mate i`ll try it tonight
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
