starting trouble
starting trouble
right chaps
just changed the alternator on me boys mondeo,jump started as the battery was dead, all good job done. car drives fine now charging fine and all is good
but
now when you start the engine with the key i just get a clicking noise and nothing else
what could be causing this
thanks
gus
but
thanks
gus
They are fun, and normally get knackered by oil from leaking rocker cover, done three now, so used sealant all around seams, and most importantly on where the little braided motor wire goes in from the solenoid, as this soaks up oil down this wire like a wick!!
The hardest bit is the driveshaft support in the way.
