tremec gear box tk 3550 will it suit a cosworth ratio wise
Old 29-07-2007, 09:54 AM
abdr500
abdr500's Avatar
Default tremec gear box tk 3550 will it suit a cosworth ratio wise
tremec gear box tk 3550 will this suit a cosworth engine & ratio wise can any one work it out please
1st 3.27
2 1.98
3 1.34
4 1.00
5 0.68
Old 29-07-2007, 10:33 AM
abdr500
abdr500's Avatar
up
Old 29-07-2007, 11:33 AM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
That 5th gear is no good whatsoever even a 650+ Cossie cant pull it.
It will give you a theortical Topspeed past 214mph @ 7500rpm on 215/40/17
You can get a .83 5th gear for a TKO so I expect its available for the 3550 thats is within 3% of a T5 .
Below will give you the speeds @ 7500 on 215/40/17 using 3.64 diff
!st 45mph
2nd 74mph
3rd 109mph
4th 146mph
5th .68 214mph
5th .83 176mph
Old 29-07-2007, 05:08 PM
escort700bhp
escort700bhp's Avatar
could u not use a 3.9 cwp with that to bring the gearing down??
Old 29-07-2007, 09:23 PM
abdr500
abdr500's Avatar
escort700bhp
2wd diff what ratio are they
Old 29-07-2007, 09:55 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Originally Posted by abdr500
escort700bhp
3.64
Old 29-07-2007, 10:02 PM
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
You could but it would be crap too big a gap between 4th & 5th. Shown below. Can you imagine changing into 5th at 136 & dropping off the end of the world .
!st 42mph
2nd 69mph
3rd 102mph
4th 136mph
5th .68 200mph
Old 29-07-2007, 10:07 PM
abdr500
abdr500's Avatar
MadRod
thanks for the info m8
Old 29-07-2007, 10:24 PM
marco polo
marco polo's Avatar
hi mate
1st gear is a bit short
2nd is ok
3rd is ok
4th is ok
5th is to low that a pure cruse gear
if you do go to a 3.9 1st gear will be even shorter not only that you will still struggle to pull the 5th gear
if you can go for ratios like 2.95 /2.97/3.00 for a 1st gear
2.10/2.07/2.00/1.94 for 2nd
1.50/1.45/1.4/1.35 for 3rd
1.1 for 4th
0.85/0.83/0.80 /0.77 for 5th dont really go much lower on 5th any of these ratios will be ok in a road car with the 3.64 or 3.62 diff
marco
steerfromdarear
28
29-01-2016 06:14 PM
JPA
08-11-2015 12:26 PM
Dicko&Vacant
21-08-2015 05:59 PM
IAN RS2k
18-08-2015 07:51 PM
14-08-2015 07:29 AM
Quick Reply: tremec gear box tk 3550 will it suit a cosworth ratio wise
