2wd exhaust manifold question
is there a small gasket that goes between the elbow part on a 2wd cosworth manifold? if not has anyone used sealent or anything like that ! also on the part where it bolts to the turbo? I ask this because there seems to be a slight blowing on my manifold and it appears to be coming from that area.
any info would be appreaciated
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
A leaking/blowin manifold is also loosing you alot of horsepower.
This is the reason my car only made 352 ATW at the AVA RR day that was in PF last year.
We were expecting it to make over 400 ATW.
Originally Posted by RWD_cossie_wil
Originally Posted by Stu @ M Developments
Use gaskets or paste at your peril.
i got both faces machined to ensure good fit. u can get gaskets to fit (believe it or not try a tractor spares dealer) just depends how much it blows out
Originally Posted by JTECHSAFF
Gaskets will be sucked in to the turbo if they fail
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
best bet is to get a machine shop to skim the two surfaces
Had enough of it so just welded it for a proper fix
final straw on the leaking manifold is when at 7500rpm in 5th on the local privat test track my oil light came on
After shitting a brick then chacking the SPA to see that oil press was fine I stopped and looked under the bonnet to see that the flames from the manifold had burnt straigh thru my heat sheild and half the wiring down the chassis leg, thus giving me hair wire dash lights
thus giving me hair wire dash lights ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
rsstav
Ford Focus RS Parts for Sale.
20-08-2015 07:45 AM
Escortdriver1
05-08-2015 12:45 PM
