Turbo feed pipe leaks 2wd sapphy
Where the metal pipe goes into the "ring", through which the BANJO bolt passes is leaking, on the coolant feed pipe, I have tonight seen one other that has come out completely on a 4wd, how common are problems here has anyone else had this ?
I am thinking of using flexi pipe when I find some suitable or some other means as this is just silly.
Thanks .
Thanks .
Decided to flexy pipe it, even if it means machining fittings up myself, as I worry about things like this, doing return as well, just to be safe.
Thanks for the input all,
09-10-2015 07:38 PM
Matt Baxter
16-09-2015 08:30 PM
JoeyBoyden
18-08-2015 10:52 PM
muz
16-08-2015 12:57 PM
