T4...GT30 ?
#42
Originally Posted by JonnyBravo
Originally Posted by staffi
Euan, that's 38psi @ 4k..............
It used to wheel spin a wee bit in the wet
#45
I actually have a peak recall in my SPA of 40 psi
Johnny the car SO isnt a track car and would be useless.
I will be on Knockhill at some point but doubt any of the big english tracks even tho I have been offered track time at Ford fair byt he nice people at Fast Ford.
#48
Gearbox looks ............ well BIG ! Is that the jag or bmw box then ?
I totally see what your saying though but atleast if it was seen on track anywhere being used slightly in anger then you couldn't be tarred with the straight line brush.
White Saphs are always the quickest eh !
Best of luck with the new turbo, seriously impressive car.
#49
Its from a XJS and says Jaguar on the casing aswell as Getrag 265.
Its in the car now and feels just like the box in my old M3, over left hard from reverse instead of the normal ford postition.
I would put my car on track but really need to sort the back axle first to try get some traction out of bends.
#52
rapidcossie
2.6 bar from a t4 i was told buy a few tunners that a t4 should not be pushed past 2 bar it wount make any more power how much pre load is on the actuator arm or is it done on the boost controler
#53
Originally Posted by abdr500
rapidcossie
#54
Staffi...I would love a shot in a well sorted set up so maybe one day
Johnny its not dog leg. Not 100 % on ratios but its I think its pretty similar to the T5.
Abdr...Im not 100% sure how the boost is controlled on my car, I do have a boost controller which runs with the managment but have also seen the actuator adjusted during set ups on rollers.
#56
rapidcossie
#58
Eaun- I remember Ryan mentioning to me about the jag box, tough as anything and obviously a fook load cheaper than most other boxes.
Are you having to get a bellhousing made ?
#60
I got it overhauled and checked and it was still under 500 quid
AVA have made a adaptor/spacer plate that makes the getrag fit the T5 bell housing.
#61
Anyway, back to the GT30 question..
I know that Kev Atkins has been running one for along time now in his Evo with VERY good success in time attack, all thanks to Sheady building yet another fantastic engine, so i think i'll give it ago, booked it in for the 20th Aug with Karl, L8 and a set of 1000cc injec
#62
Speak to Mark about GT turbos as his engines are the only ones that dont seem to surge with the GTs.
#66
Originally Posted by RS500/364
Ahmed said they can make a T4 less laggy than my T34.63
As if he can improve a T4 spool as good as a T34, then he could also improve a T34 spool up so its as quick as a T3. and so on.
its all down turbo spec, engine spec, cam timing and mapping.
Boost plot.
Very similar to my GT30 boost, as i can get 35+ psi @ 4000 rpm.
i haven't played with the cam timing yet, so should be able to improve.
i cant comment on a T4 as never had one, or driven a car with one.
but my GT30 is fine. and once i actually do some testing on a RR and finish the setup, i cant comment on how good it will be.
#67
hi euan
im on about none modded normal old garrett turbos , yours is modded like i said the only have 3.5k power band ask any tunner
normal To4 4k-to 7.5k starts tailing off then
normal T34 3k to 6.5k starts tailing off then
noraml T03 2k to 5.5k starts tailing off then
marco
marco
