anyone on here use zymol waxes etc?
with the right prep, ie polish sealers or cleanses zymol is fantastic.
think they do a starter kit
http://www.vertar.com/zymol/zymol-starter-kits/
£99 the cheapest
£99 the cheapest
zymol cleaner wax was great stuff, was in a bottle and greenish blue in colour ,gave great results and smelt wicked! not sure if you can get it still tho
Originally Posted by NIL 7717
that aint too bad depending on what you get.will have to hunt for the info on how much you get.was wondering if its worth changing from meguiars.
poorboys is also excellent, i use a lot of there polishes and trim cleaners.
all depending on what you are using, a machine or hand to polish and wax.
if by hand then you will probably not see much improvement over the meguiars apart from perhaps a deeper longer lasting shine.
if you are going down the machine polishing route id highly reccomend the menzerna range of polishes and then zymol as a sealant/glaze.
I used to use this before I moved to Poorboys which says a lot for poorboys , I was using Carbon to start with and then I changed to Titanium, all applied properly with HD cleans etc, it is good but I think Poorboys is better and it is MUCH cheaper, I have seen very good results with their Concours glaze though
I think it depends on what finish you want also, as MATCOS said i also use poorboys as its better in some areas n also cheaper but i do like the finish of the zymol waxes over any of the poorboys such as natty blue.
you will end up like me and most others probably with a shelf FULL of polishes waxes, sealers and glazes lol.... its an expensive hobby keeping ya car clean
Originally Posted by jaiscossie
personally i dont think you can beat p21s as a last coat wax as long as your paintwork is perfect as this is just pure wax
Adam Graham
06-09-2015 06:04 AM
Sid
52
09-05-2006 06:35 PM
Benn 304R
15-02-2006 08:16 PM
