URGENT HELP
Hi !
There is modifications or make an adjustement on cylinder head for fitting a Kent valve springs or it's just disassembly and reassembly ?
The kit number is : VSK 32 P
It's for fit BD14 inlet and BD10 exhaust.
Regards.
Regards.
You measure from the VALVE SEAT area on the head to the UNDERSIDE of the SPRING retainer, 34 MM IS OPTIMAL BUT 1/2MM EITHER WAY IS OK TOO.
Just do a dummy fit with a weak spring, out of anything to measure.
DaveN
13
09-01-2005 06:19 PM
