5th Injector Drivers.....
Old Sep 23, 2004 | 06:07 PM
scort's Avatar
scort
Default 5th Injector Drivers.....
How do they work?
Do they rely on boost? rpm? throttle position??
Thanks,
Steve
Old Sep 23, 2004 | 06:43 PM
Lee Reynolds's Avatar
Lee Reynolds
RPM....you set it to come in a whatever RPM i beleive!
Old Sep 23, 2004 | 07:13 PM
BODGE's Avatar
BODGE
the MF2 driver works off a boost presure switch
mark
Old Sep 23, 2004 | 07:43 PM
Rick's Avatar
Rick
or of a map sensor and engine rpm
Old Sep 23, 2004 | 07:58 PM
scort's Avatar
scort
So I could make my own injector driver using a pressure switch in the inlet?
Steve
Old Sep 24, 2004 | 05:36 PM
scort's Avatar
scort
Old Sep 24, 2004 | 05:37 PM
Oranoco's Avatar
Oranoco
Buy the kit and do it properly. When these things are DIY'd they have a horrible habbit of ending in expensive tears
Old Sep 24, 2004 | 05:41 PM
Hofajoab's Avatar
Hofajoab
scort, i'll be running a 5th injector setup with a pressure switch but i'm also going to get an AFC running as well, and the 5th injector will be a little larger than i need. I can then lean out the normal injectors when under 'boost' for a bit of fine tuning, well as fine as you can get on a budget.
Old Sep 24, 2004 | 05:46 PM
scort's Avatar
scort
I see,
Its for a project. I have a boost retard unit. Its for a janspeed sierra.
If i had a tell tale light on the dash, coming on at the same time as the injector, then it would act as a safety mechanism.
What is an AFC?
Steve
Old Sep 24, 2004 | 05:49 PM
Hofajoab's Avatar
Hofajoab
air fuel controller...
basically, as far as i know it just manipulates the air flow signal to the ECU, tricking the ECU to either run lean/rich at specific RPM's and throttle position etc.. I was thinking i could just switch the airflow signal in and out between the original one and the AFC one using the pressure switch.
hope that makes sense.
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Chas
Oct 5, 2015 07:13 PM
