4x4 coilovers on 2wd
23-06-2007, 06:21 PM
what is needed to fit 4x4 front coilovers to my 2wd cossie
thanks
23-06-2007, 06:23 PM
Live long and prosper!!
Won't fit as the hubs are different the 4x4 ones are bigger i think
23-06-2007, 06:25 PM
you need 4x4 hubs.
you can get a sleeve made to mae then fit,or is that the other way around....2wd onto 4x4 or 4x4 onto 2wd.
so will i only need a set of 4x4 front hubs?
23-06-2007, 06:27 PM
Quote:
all the same everywhere else, just where they sit in the hub,the hole is too big or too small...not sure.
one will go into the other though with a sleeve.
just buy 2wd coilovers.
23-06-2007, 06:30 PM
Former Sponsor
the only thing different is the actual damper tube if they are bilstiens,everything else is the same,so all you would need is a pair of 2wd tubes,the insert etc will all fit into it.
23-06-2007, 06:34 PM
You could use 4x4 hubs but u will need to have the end of the shaft still in there so extra weight
23-06-2007, 07:47 PM
As said 4wd ones thicker tube.
23-06-2007, 08:36 PM
dicko, speak to rob he fitted some to his sierra using a sleeve to make the gap up, or if there cheap let me buy them for the track car!!
**edit** ignore that bollox above rob fitted 2wd ones into a 4x4 hub, he might do a straight swop tho!!!
steve
23-06-2007, 09:51 PM
Or get your hubs machined out
I have a set for sale
23-06-2007, 10:06 PM
Former Sponsor
but they would be rather thin would they not?they are essentially a stressed clamp,i wouldnt like to risk that!
mark r
29-09-2015 07:27 PM
rog
16-09-2015 03:00 PM
tib2220
14-09-2015 12:33 PM
truffleshuffle
10-09-2015 09:35 PM
Adam Graham
06-09-2015 06:04 AM
