How to unblock a shower drain?
My shower is a pain in the arse at the mo as the drain is really slow and water builds up in shower cubicle. I guess this is due to the amount of fucking hair that collects due to my mrs washing her hair and letting everything go down the plug
I have plucked out the obvious stuff but how the hell can i do the rest? Is there anything you can pour down to unblock or what?
You want one of these including the large cup.
http://www.tooled-up.com/ManProduct....-Drain-Blaster
Use it to suck the hairs / soap back up the drain into the tray.
Then use it regularly to keep the drain clear.
You can get them from B & Q or Wickes but they cost a lot more
They will suck and blow, if you push the blockage down you risk blocking the pipework up lower down or even blowing the pipe work apart at a join.
I've been using the same one for years in commercial buildings.
Originally Posted by smitsturbo
get yourself under the floor boards & undo the piping & check it out
Alex
DOes it break down the hair or what? I wondered if something could do that. I guess thats an asda purchase so might also look there.
I tell ya i fooking hate standing in the shower when the water is up to your ankles
