injector question
Old Jun 19, 2007 | 07:26 PM
DangerousBryan's Avatar
DangerousBryan
Default injector question
not ford but vauxhall on a cavalier turbo.
the standard injectors are bosch yellows(same as a cossie?)
these have four holes in the end to inject the fuel into the engine. i bought some 440cc injectors from racetronix in the states,i think they are delphi ones. but they only have three injection holes in them.
will this make any difference? will it make it run any differently,blow up,etc,etc?
thanks,bryan
Old Jun 19, 2007 | 08:00 PM
Billabong's Avatar
Billabong
Dunno what Cav Turbos run, but the Cossie 'Yellows' aren't Bosch, they're Weber injectors, and I'm pretty sure they run one 'hole' / pintle.
I presume you've made sure the injectors are of the same impedance as the standard ones? Can't really help otherwise, although Chip knows a bit about Vauxhalls, so may be able to help.
Old Jun 20, 2007 | 07:55 AM
So long as correct flow rate/impedance will be ok.
Delphi is LUCAS btw.
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
