f@@@in fault with esco still...................now fine
Old 12-06-2007, 10:26 PM
col cos1
col cos1's Avatar
Default f@@@in fault with esco still...................now fine
yous might remember i posted up this fault my mates esco cos has got
wel its still not gone...so basically car has had this fault on and off for a while now(1=2 years)
the car when revved up to 4k it backfires like fuck,looses boost and cuts out.at 1 bar of boost
this was running stage 3+for running in new engine
tonight we put the greys in +msd closed loop chip and the boost must be set diffrent on this map as it doesnt come in as quick and now it revs to 5500 on only 10psi and does the same thing
we are at our wits ends with the thing
its been in a garage 3 times for this and still the same
all sensors,ecu changed except knock sensor and tps
there is a great spark,plenty fuel getting through,and all engine wiring inspected and part rewired
nightmare
m.rainbird,stu(msd)m.reyland,m shead.............help
Old 12-06-2007, 10:55 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Still on P8?
Old 12-06-2007, 10:59 PM
rapidcossie
rapidcossie's Avatar
what did alan think it was?
Old 12-06-2007, 11:00 PM
col cos1
col cos1's Avatar
no stu its on level 8 for some reason it must of been changed when it was reshelled
think he ordered chip from you for p8 but had to send it back for exchange mate
Old 12-06-2007, 11:07 PM
col cos1
col cos1's Avatar
alan said he`d cured it,as a recuring fault,it was ok when the previous owner got it back but 100miles later it was back
sure alan changed alot of sensors,ecu etc,but it came back
Old 12-06-2007, 11:15 PM
col cos1
col cos1's Avatar
im sure alan rewired part of loom aswell euan
frasers even bought a new ecu for it still no luck
Old 12-06-2007, 11:18 PM
thebigyin
thebigyin's Avatar
you tryed it with a different exhaust? or no exhaust at all if you can without annoying the neighbours
Old 12-06-2007, 11:23 PM
thebigyin
thebigyin's Avatar
the symptoms you describe dont totally say exhaust to me,but judging on what has already been done its got to be worth a go before wasting more time and cash,i have seen exhausts cause this kind of fault,even intermittently,strangely
Dan@Rapid-Ford
Dan@Rapid-Ford's Avatar
Is the crank pully std or is it an aftermarket ally one?
Old 12-06-2007, 11:28 PM
col cos1
col cos1's Avatar
crank pulley is standard
exhaust u think??
worth a try
Old 13-06-2007, 10:46 AM
Mark 3D
Moderator
Mark 3D's Avatar
my 3 door had a similiar issue.
as soon as the L8 ecu was fitted it was sorted.
Could you have a faulty ECU?
Old 13-06-2007, 10:50 AM
bud-weis
Football Cwazy
bud-weis's Avatar
presuming that mechanically the car is sound ( which i'm sure it is ) then it definitely sounds electrical IMO...
Old 13-06-2007, 11:04 AM
Phil79
Phil79's Avatar
I know exactly what the problem is. I have had it with numerous cars in my time. It's all down to this at the front
simple fix, but a big step to do.
SELL IT
Old 13-06-2007, 04:21 PM
col cos1
col cos1's Avatar
ecu been changed twice
Old 13-06-2007, 04:22 PM
col cos1
col cos1's Avatar
yeah totally sound,this fault was there with old engine
now its got a new completly rebuilt diffrent speced engine
Old 13-06-2007, 04:24 PM
Mark 3D
Moderator
Mark 3D's Avatar
bugger!! cant be that then!!
i take it youve changed all the spark plugs and leads etc
Old 13-06-2007, 07:23 PM
TurboInsania
TurboInsania's Avatar
hello right i am colins pal that has this prob with this cossie and it is driving me crazy PLEASE HELP ANY BODY HAD THIS PROBLEM
Old 13-06-2007, 07:29 PM
TurboInsania
ye it has had leads the lot its such a weard fault as it only happens when the car is under load then u need to turn the car of and restart it and its perfect
Old 13-06-2007, 08:14 PM
pani_k
PassionFORD Member
pani_k's Avatar
something odd must be going on and dare i say it, it could be the ECU program. try re-programming it.
Old 13-06-2007, 09:15 PM
silky16v
Get on That!
silky16v's Avatar
wiring to the map sensor
also common fault is the the multi plug still there in engine bay
also check main voltage to the ecu when the car is running and driving (do this by putting a volt meter to the correct pin-out on the ecu connector)
Old 13-06-2007, 09:20 PM
rapidcossie
fraz, its nothing to do with that funny fuel set up?
Old 13-06-2007, 10:04 PM
glancy2081
glancy2081's Avatar
voltage at fuel pump,fuel filter partially blocked pressure
Old 13-06-2007, 10:49 PM
M7 COS
M7 COS's Avatar
There's a post similar to this one in the Escort Cosworth forum.
Old 13-06-2007, 10:53 PM
TurboInsania
right ecu babyboard and chip all been changed the multiplugs av been cut out and hard wired plenty fuel and prob was there before external pump was fitted euan and i avnt got much hair left to pull out lol
Old 13-06-2007, 10:58 PM
ian sibbert
ian sibbert's Avatar
Fuel pump / gauze on the pickup or the fuel pressure reg....
I have had several that seem like an electrical fault and it turned out to be either
Fuel Pump Voltage/Wiring
Fuel Pressure Reg Diaphram usually.
Pick up on the fuel pump, most have some sort of gauze/strainer on the pickup which if partially blocked can give similar probs as you describe....
If you have exhausted all the other sensor/electrical avenues....
Old 13-06-2007, 11:05 PM
TurboInsania
give u an idea i got the car without an engine totally standard the car had this fault and when i picked up the car it was in the garrage for this fault and unfortunatly the engine let go when the garrage had it and since then has had a top spec rebuild external pump so on but u say the regulater that is 1 thing i aint actually looked in to maybe worth a nose
Old 14-06-2007, 07:02 AM
Missfiring and losing boost actually suggest its losing fuel dramatically. It may well be that you have a fuel supply problem. Has anybody checked teh AFR whilst this problem is occuring?
Has anyone watched teh ECU datastream whilst this is occuring?
Old 14-06-2007, 08:45 PM
col cos1
col cos1's Avatar
fraser defo get that pump changed asap mate
i know its not the fault as it done it before you changed it but it defo dont sound right
Old 14-06-2007, 09:45 PM
TurboInsania
right good news looks like it the middle wire on the throttle position switch.It has sucked up water by cappilary and its screwed the cable so the wire came out my hand when i checked it today, and when i hard wired the engine loom plugs beside the coil i noticed 1 wire was the same and its the same colour.So i might just replace that wire on its own but i dont no if it gos straight there any body shed sum light and thanks for the info today on the phone stu set dizzy up spot on
Old 15-06-2007, 12:12 AM
Turbosystems
Super Moderator
Turbosystems's Avatar
these cars are at least 10years old now the looms where never any good all cossies need a proper wiring loom such as pectel these are available and start at 550 +vat
Old 15-06-2007, 05:12 PM
TurboInsania
thanks for the info every body
Old 29-07-2007, 05:14 PM
col cos1
col cos1's Avatar
update
new engine wiring loom fitted to car............................................... ...................its cured the fault and goes like f@ck
looking fwd to seeing what it will do on the rollers
Old 29-07-2007, 07:13 PM
col cos1
col cos1's Avatar
was out in car tonight
first time ive been in a t38 equiped coss
doesnt half spin up fast
slight flat spot just as the boost comes in,good set up on the rollers at weekend hopefully
Old 29-07-2007, 07:17 PM
KSA-Cossie
KSA-Cossie's Avatar
Nice one col.
Old 29-07-2007, 07:23 PM
glancy2081
glancy2081's Avatar
glad to hear that the problem has been fixed
Old 29-07-2007, 07:29 PM
col cos1
col cos1's Avatar
CHEERS GUYS WAS DEFO SOME KIND OF WIRING FAULT
Old 29-07-2007, 07:33 PM
NEIL A
NEIL A's Avatar
Who did he end up getting a loom from col and how hard was it to fit, might be worth thinking about.
Old 29-07-2007, 07:34 PM
KSA-Cossie
KSA-Cossie's Avatar
Looms are a doddle to fit neil carlooms uk do them .
Old 29-07-2007, 07:40 PM
NEIL A
NEIL A's Avatar
Realy did think about it while the engine is out but , never had a problem with any of the wiring on my car and its only done 50K.Dont reay want to keep adding to ava's work list either as my spec has changed a few times since its been in.
Old 29-07-2007, 07:59 PM
col cos1
col cos1's Avatar
neil he bought it off harvey gibbs i think,it was a standard one out a concours car £big note
it wasent as easy as it should of been i dont think due to some of the old loom being hard wired by someone else and things didint match up
but hes soldered and heat shrinked all of it etc and it seems to be fine
Quick Reply: f@@@in fault with esco still...................now fine
