twin air injectors
Old 13-06-2007, 08:47 AM
  #41
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Originally Posted by GARETH T
no reason why you cant,,,, and ive tried it
but the reason for using air to air boost control is that the actuator doesnt see any pressure untill you want it, this stops the wastegate creeping open
Correct.
In some cases, especially rally cars with massive midrange spikes of 50psi etc, we have so much turbine housing pressure that we cannot have any capsule assistance pressure at all otherwise our desired boost pressure is unatainable due to too much assistance.
Old 13-06-2007, 09:07 AM
  #42
foreigneRS
Testing the future
foreigneRS's Avatar
with the 'bleed on' method, how is the boost controlled? i presume that there must be a map of air injector duty vs TPS and MAP or something?
what then happens if the wastegate weakens or something else changes? presumably you don't get the same boost as when it was mapped?
wouldn't a close loop boost control system be better, where you have boost vs rpm that you can set? i suppose that is what most standalone boost controllers do, but wouldn't it be better to have the ecu controlling it? i guess T6 can do that sort of thing?
Old 13-06-2007, 09:13 AM
  #43
GARETH T
GARETH T's Avatar
you can set a duty cycle of throttle angle/rpm
or you can close loop it
Old 13-06-2007, 09:24 AM
  #44
RS500/364
RS500/364's Avatar
And he still dont know were to get them maybe on rallyspares.com or google search
Old 13-06-2007, 10:27 AM
  #45
Really? What was wrong with the first reply to teh topic?
Originally Posted by Billabong
Harvey @ SCS, Ahmed Bayjoo, Mike R
Old 13-06-2007, 10:29 AM
  #46
Correct. Map Vs RPM.
Correct Again.
Yes, definately.
100% success there at answeering your own questions.
Old 13-06-2007, 12:12 PM
  #47
foreigneRS
Testing the future
foreigneRS's Avatar
thanks stu. confirms that i do still understand some things
Old 13-06-2007, 01:55 PM
  #48
RS500/364
RS500/364's Avatar
SOD IT I BE MORE SPOT ON
AHMED
07740189852
HARVEY
01733576614
MIKE R
01508557822
I GOT SOME IN THE BACK OF THE RS500 FROM A1RS DIDNT USE THEM
01767691617
Old 13-06-2007, 03:19 PM
  #49
GARETH T
GARETH T's Avatar
wrong stu
Old 13-06-2007, 03:49 PM
  #50
wrong stu
Wrong why Gareth?
Weber has a duration table that runs RPM along the Side and Manifold pressure along the top mate.
Old 13-06-2007, 04:12 PM
  #51
GARETH T
GARETH T's Avatar
ahh shite,, i was being a little single track minded,,, t6
Old 13-06-2007, 04:15 PM
  #52
Old 13-06-2007, 04:23 PM
  #53
GARETH T
GARETH T's Avatar
i do find it odd that boost is on one of the axis when you are trying to control boost!
Old 13-06-2007, 04:39 PM
  #54
I would have been dissapointed if you hadnt noticed that Gareth mate. Top Marks... it is a tad unusual and almosty seems counter intuitive, but it isnt actually...
What we can do with MAP is keep the wastegate fully closed right up until the boost pressure we are trying to control, then start to open the gate. This is something you cant easily do with TPS based boost control as you can have different boost with same throttle under some circumstances, such as load of course. If we need to keep boost low at some point in the rev range, we can dial in smaller numbers on that part of the map.
Old 13-06-2007, 04:42 PM
  #55
ECU Monitor Enthusiast
Billabong,
Only difference between the old twins and my singles is the cost.
Well, if you ignore the fact mine are lighter, smaller, easier to mount and less likely to fail. Apart from that, the only difference is teh price.
oops, i forgot that they also consume less juice from a a power circuit which, on most cosworths, is allready threatening to take the engine out due to pathetically low voltages to pumps, injectors and ecus...
  #56
GARETH T
GARETH T's Avatar
thanks for clearing that up stu
Old 13-06-2007, 05:50 PM
  #57
markk
markk's Avatar
i have had a single air injector stick wide open dont really know why it failed tbh made very very low boost pessure as you can imagine
Old 13-06-2007, 06:41 PM
  #58
Billabong
Billabong's Avatar
Originally Posted by LS35A
Billabong,
Not really Simon, as I seem to remember the first single air injectors weren't flowing exactly twice as much as each air inj' in the twin set up - which is what I was referring too, and it was Stu who posted it. I am however happy to be corrected by Stu (and yourself ), as this no longer appears to be the case
Old 14-06-2007, 11:40 AM
  #59
Your always very welcome pal.
Old 14-06-2007, 09:04 PM
  #60
DazC
DazC's Avatar
Single injectors flow 1580cc.
Old 14-06-2007, 09:10 PM
  #61
foreigneRS
Testing the future
foreigneRS's Avatar
of what over what period of time? my arse flows 7.23 tonnes
  #62
Deleted by Request
Former Sponsor
Deleted by Request's Avatar
..842's actually flow 1200cc @ 1.2bar.
Old 14-06-2007, 09:19 PM
  #63
DazC
DazC's Avatar
Can't remember exactly, I just have that figure lodged into my head from when I looked at them ages ago!!
Old 15-06-2007, 04:13 AM
  #64
RS500/364
RS500/364's Avatar
WHATS THE PART NUMBER ON THE TWINS I GOT A FAULTY ONE AND THE VALUE OF THE RESISTOR NEEDED
01-11-2015 06:53 PM
Brickhouse
14
03-10-2015 07:28 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
Steve Escos
01-10-2015 06:57 AM
stevecfrst1
30-09-2015 05:18 AM
Quick Reply: twin air injectors
