Dyno Dynamics Rolling roads
#43
Hi Guys,
the grip on the rollers and the traction bar hold a car into the rollers properly - the more power it makes the more grip it makes
the higher tyre pressures stop the tyres distorting and the sidewall from buckling under higher power (a bit like you see on a dragster as it leaves the line)
the biggest power we have run in the UK was 1,875 atw - a twin turbo corvette
here are some vids for you to see some of the big power stuff
Some bigger HP cars
http://www.youtube.com/watch?v=Q9I0WxjWvkg
1336 HP at the rear wheels
http://www.xr8chic.com/images/summer.../dyno_1336.mpg
1311 HP at the rear wheels
http://www.aussieimportsllc.com/tassone-dyno.mpeg
1023 bhp at the rear wheels
http://www.aussieimportsllc.com/hphero.wmv
A Dyno Competition in sweden
http://www.tsmotor.com/images/elmia2007.wmv
Some bigger HP cars
#45
Originally Posted by Mike Gurney
Hi Guys,
Some bigger HP cars
Some bigger HP cars
#46
Originally Posted by Gary @ APT
we have 2 bars one for front too when we get a big bhp 4wd
Good to see you Mike
480whp is easy to run in 4wd
#48
should be next wed mate,but at moment the head is with machiners and looking like its going to be close to getting back and turbo is still having a check up
#51
Originally Posted by Paul Ripley
Radders yes mate
Bassboy my mates mate works at a Jap tuning firm called Perfect Touch which is local to me, based in Hoddesdon, Herts
Couldn't afford a proper one
#52
dyna pack not dd!!
Completely misread!
Still the question stands - why are more tuners not using hub dynos so there can be no tyre slip situations?
#53
dyna pack not dd!!
Completely misread!
Dont have any issues with wheel spin personally, so cant comment really....
Not very quick and easy to get cars on/off at a guess.....
#55
Third Gear !!!
So... perhaps that is why my 500 never made decent power at G-Force at the Beds RR Day all those years ago.
Those fellas ran the cars in 4th......
Obviously hadnt read the manual....
#57
Testing the future
How about the DD hub dyno's? PJ uses one. Surely these will allow the truest power figure and best mapping because there is no wheelspin.
but then so will a rolling road, and so will an engine dyno
as long as the measuring device is calibrated, then you can say that it will be accurate
it may not be the same actual power produced though, as there will be other factors that affect that - such as ambient temperature, pressure, water temperature etc. and as i said before, the most important factor to making power on a forced induction engine is the intercooling which will most likely not be the same on a chassis dyno of any kind as it would be on the road (unless it's in a full on wind tunnel)
this subject does not really require any argument - it's quite simple engineering principles
