Maximum boost from a T25 ??
Old Jun 5, 2007 | 04:26 PM
AndyBrew's Avatar
AndyBrew
Default Maximum boost from a T25 ??
has anybody got any informed views on what the maximum boost for a T25 would be on my esc cos???
not bothered about stressing the little bitch as its coming off shortly anyway, but I would like it to get me to Le Mans and back
it will be running OMEX 710 management, 750cc injectors and an upgraded fuel pump.
Any guestimates on bhp and torque??
Please discuss
Old Jun 5, 2007 | 04:32 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
270bhp and it will be on it's knees at that .
Old Jun 5, 2007 | 04:33 PM
pani_k's Avatar
pani_k
PassionFORD Member
would have thought it could run MAX 1.2-1.5 BAR (I think).
turbo_3dr_tommy's Avatar
turbo_3dr_tommy
thaught it was a t28 on a small turbo cos
and a t25 is on a fiesta turbo
or am i just thick
Old Jun 5, 2007 | 04:38 PM
pani_k's Avatar
pani_k
PassionFORD Member
T25= small turbo'd escos
T34= big turbo'd escos
T28 is the Nissan turbo isn't it?
Old Jun 5, 2007 | 04:41 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
T25/T28/T35 means bugger all, just a vague explanation, countless examples and types of loads of cars.
T25s on S13s and T28s on S14s though.
Id suspect a EscCos turbo is closer to what most would call a T28 tho.
Same manifold flange tho, a T2 one.
AndyBrew's Avatar
AndyBrew
mine has currently got a TurboSystems stage 1 chip and it was rolling roaded at 270hp / 300lbs I think it boosts to 1.3bar, surely 300 is possible????
Old Jun 5, 2007 | 04:42 PM
turbo_3dr_tommy
lol guess I'm thick then
Old Jun 5, 2007 | 04:44 PM
AndyBrew's Avatar
AndyBrew
I've seen both quoted, but it says T25 on the RSOC web site so I thought they MUST be right
maybe not LOL!!!
Old Jun 5, 2007 | 04:46 PM
pani_k's Avatar
pani_k
PassionFORD Member
I only quoted T25= small and T34=big because that's what power engineering have on their website for the two escosworths
Old Jun 5, 2007 | 04:47 PM
AndyBrew's Avatar
AndyBrew
I think T25 was the offical spec. whether its wrong or right is another matter
Old Jun 5, 2007 | 04:53 PM
pani_k's Avatar
pani_k
PassionFORD Member
The big turbo cossies I think were the first ones. I think the later ones they changed the turbo to the smaller one. Although I stand to be corrected on that as I'm not too sure
Old Jun 5, 2007 | 04:58 PM
AndyBrew's Avatar
AndyBrew
no that is definately correct
Old Jun 5, 2007 | 06:16 PM
Stu @ M Developments's Avatar
PassionFords Creator
Its a T28 and it will do 20psi quite happily although the thrust load is a little excessive and i would advise a decent thrust upgrade.
No offence intended and its none of my business, but why upgrade the WHOLE mananegemnt to only run 300bhp?
You could achieve that with mail order parts on your escos and retain a decent ECU!!
Old Jun 5, 2007 | 06:20 PM
rssteve's Avatar
rssteve
sounds like he is upgrading the turbo anyway.
Old Jun 5, 2007 | 06:27 PM
Yes, just re-read it PROPERLY and can see that its coming off after LeMans.. and it was perfectly clear too. sorry.
Old Jun 5, 2007 | 07:18 PM
SapphyMike's Avatar
SapphyMike
wont running too much boost possibly lose power through the heat generated though?
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
