Re-programming Fiesta Zetec-S 3 button keyfob
The std radio key fob (3 button one), one still works the other is dead. I've tried:
Insert the ignition key and turn from position II (Ignition) to position 0 (All off) and back four times within three seconds.
Remove the ignition key. The locking control system is now in "learn mode" for the next 20 seconds and the red warning system LED (By the clock) stays on continuously to indicate this.
During the 20 seconds press one of the transmitter buttons. The remotes signal and code number is learned by the locking module and is indicated by flashing the warning system LED.
Wait until learn mode times out (20 seconds) or switch the ignition back to ON.
The LED on the dash does not stay illuminated but does register when I press the unlock button on the working remote, and not on the dead one.
Any other methods? Can't find it in the manual with the car.
Changed battery in fob also!
Changed battery in fob also!![Wall](https://passionford.com/forum/images/smilies/wall.gif)
cheers
martyn
Steve Escos
01-10-2015 06:57 AM
2008, button, coding, fiesta, fob, ford, key, local, mk5, program, programing, programming, reprogramming, st, zetec
