timing for efi engine
Old Jun 2, 2007 | 07:57 PM
jonesymk2's Avatar
jonesymk2
Default timing for efi engine
what should the timing be,the haynes manual says 12degrees btdc for efi xr3i on tickover but would it be different if it was turbo,also what should it roughly be at say 2000rpm,3000rpm and so on,also does the ecu adjust the timing
Old Jun 3, 2007 | 08:46 AM
jonesymk2's Avatar
jonesymk2
anybody
Old Jun 3, 2007 | 12:48 PM
GARETH T's Avatar
GARETH T
timing is dependant on load aswell!
Old Jun 3, 2007 | 01:14 PM
xr4x4rs's Avatar
xr4x4rs
if its a efi xr3i then the igntion timing is fixed as its coil pack
Old Jun 3, 2007 | 06:24 PM
jonesymk2's Avatar
jonesymk2
oh right ok then,yeh it was an xr3i loom but im running an ofac ecu now 4 turbo
jonesymk2's Avatar
jonesymk2
wud it b the same as tickover then if the car was just sat still
Old Jun 3, 2007 | 06:25 PM
xr4x4rs's Avatar
xr4x4rs
so its coil pack
then theres no wat to adjust the igntion timing manually
alls you can adjust is the cam timing
Old Jun 3, 2007 | 06:30 PM
GARETH T's Avatar
GARETH T
sadly not mate
Old Jun 3, 2007 | 06:31 PM
jonesymk2's Avatar
jonesymk2
oh right ok then i was just curious as 2 if it gets adjusted by the ecu if it was turbo then,also does the flywheel only go on 1 way then
Old Jun 3, 2007 | 06:33 PM
Wardy257's Avatar
Wardy257
The ECU will adjust the timing, all you can do is adjust the static timing. If you modify the engine your best be is an aftermarket ECU so you can adjust the timing (and fuelling), especially if you go turbo.
Old Jun 3, 2007 | 06:35 PM
jonesymk2's Avatar
jonesymk2
sadly not mate
oh right ok then suppose theres no chance of knowing what it should b then at different revs
Old Jun 3, 2007 | 06:36 PM
jonesymk2's Avatar
jonesymk2
what do u mean by the static timing then,do u mean at idle,how can u adjust that then
Old Jun 3, 2007 | 06:47 PM
xr4x4rs's Avatar
xr4x4rs
Wardy257
what i meant was there no way of adjusting it manually like a dizzy as this is the way i thought he was thinking
flywheel will on go round 1 way yes
Old Jun 3, 2007 | 06:53 PM
jonesymk2's Avatar
jonesymk2
Originally Posted by xr4x4rs
Wardy257
oh right yeh i understand i thought it might only b able 2 b adjusted by the ecu,i just had 2 make sure the flywheel omly goes on 1 way aswell,wud the timing b different on tickover if the ecu had a chip plugged in
RUBY123
Oct 22, 2023 12:04 PM
EoinXR3
Sep 7, 2015 05:44 AM
marky_g
Aug 17, 2015 12:21 PM
Bailes1992
Aug 16, 2015 07:14 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
