Whats needed for closed loop Lambda control...
Old May 28, 2007 | 12:12 PM
Mr C's Avatar
Mr C
Default Whats needed for closed loop Lambda control...
I have a 4x4 200 block YB engine and L8 ECU, I have all the parts like twin ign amp, loom, leads and MSD EVO Stg3 chip etc and am only minus the Driver board but Im waiting on a price from Stu on the new ALS and launch control driver
My question is what do i need to run my ecu on closed loop, I have a lambda probe and boss to weld into the down pipe, is the sensor just ready to wire into the ecu, anything else needed to get L8 to run this
Regards Mark
Old May 28, 2007 | 12:18 PM
xr4x4rs's Avatar
xr4x4rs
if its a std 4x4 loom you have im sure theres a plug already there for a lambda sensor
then its just simply plug the new chip in
i think!
Old May 28, 2007 | 12:20 PM
Mr C's Avatar
Mr C
oh and I have a new MWS engine bay loom from a 2wd to use. so will have to swap TPS and wires over apart from that. I will check for a sensor connector on the loom, you never know.
Old May 28, 2007 | 12:41 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
lucky you reminded me your boss will be posted first thing sorry fogot lol
Jasesapphy's Avatar
Jasesapphy
Need a PF09 also
Old May 28, 2007 | 12:44 PM
Mr C's Avatar
Mr C
Thats it then, PF09 TPS, TPS wire swap on loom, boss welded in when Roosie gets it out to me and hopefully a plug allready on my loom otherwise a new £600 MWS bay loom may be for sale swap for a 4x4 item tut
Thanks gents
Old May 28, 2007 | 01:03 PM
xr4x4rs's Avatar
xr4x4rs
Mr C
hows the car coming along now mate
your mate cae round a few months ago and got some stuff off me says you sold the roll cage?
Old May 28, 2007 | 01:13 PM
Mr C's Avatar
Mr C
Hi Rich, yeah I sold the road car, cage and other stuff I didnt need in the end as I bought a rally car shell and swapped the bits into that, worked out better financially, made more sense, less of a compromise, still got a lot of fitting up to do but money is tight to say the least now I have a house with the missus, mortgage first I have a project post started but not updated it for a while, I need a decision on the clutch first then I may finish the build, Aeroquip is the next big purchase ££££ but monthly payments are priority tut.
Hows your RS XR4x4 going, I will check your post, Jay said he had been over again
Regards Mark.
Old May 28, 2007 | 02:53 PM
xr4x4rs's Avatar
xr4x4rs
yeah he came over need some interior bits
mines getting there
got the engine in the other day
next is turbo and wiring loom and then i can get the thing rolling and running
then off to paint
so not much left now
Old Jun 11, 2007 | 07:30 PM
Mr C's Avatar
Mr C
update, my wiring loom doesnt have the oxygen sensor wired in and is indeed from a 2wd , anybody know how these are wired in, is it just to the ecu pins- if so which ones and who on here does wiring loom parts and can knock a little loom part up for me? Ryan was it or anybody else recommended???
Old Jun 11, 2007 | 07:43 PM
Stu @ M Developments's Avatar
PassionFords Creator
Default Re: Whats needed for closed loop Lambda control...
£350 ALS
£250 LC
£500 both at once. All prices inc vat.
Decent chip with closed loop conrtrol software in it.
3 wires from your lambda.
wire 1 = chassis ground
wire 2 = fuel pump relay live
wire 3 = connect to ecu pin 2.
No, nothing.
blackbeautyzetec
Aug 29, 2015 02:11 PM
Dahl88
Aug 22, 2015 08:16 PM
RsS2daz
Aug 14, 2015 05:26 AM
col93saphcos
Aug 7, 2015 03:21 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
