Is 'TFC important?
#41
PassionFords Creator
Originally Posted by JjCoDeX75
Originally Posted by Stu @ M Developments
Originally Posted by Rick
Stu, what is the minimum pulse witdh change that L8 can do, and what sort of pulse width do u see on a 2 litre with 1000cc injectors? And does this factor in the injector opening time? THe actual fuel delivery period must be under .2mS!
1000cc at std fuel pressure requires around 1.3ms total time at idle.
Given the above, and the limitations of the computer speeds of the time (compared to the modern stuff), in the hypothetical situation where an injector at idle required an open time of 0.2ms, would the solution not be to reduce the fuelling pressure on the rail in order to allow the injector to work for a longer period?
JJ
#42
Interesting. So presumably the engine design and injector location etc affects the susceptibility to poor fuel atomisation. I only ask because I understand that the Scoobies for example work at a lower fuel pressure than the cos?
JJ
JJ
Tony W
09-09-2015 12:08 PM
