Difference between -31 and -34
PassionFords Creator
Originally Posted by Alps Pacino
Just wondered what the difference was between the two types was.
And what is the best type to get really
Stu @ M Developments
So i'm basically fucked then lol, its a t35 .55 stg3 hybrid ??????????????
Running greys bd14's etc etc its meant to be peaking just over 30psi and holding 28psi apparently. Boost control is just the amal valve ??????
Its got a -34 on it already but its a big shinny purple thing and tbh looks like a bellend. I was just wondering if there were certain makes of the -34 that are better than others. The forge ones look like a nice bit of kit but i'd prefer function over fasion
just before i order 1, it is the 2wd lenght actutor i need isnt it, as its got a 2wd manifold and t34 so the actutor is on the bracket ontopp of the turbo and not on the side like a standard escort cossie????????????
CossieRich
Is it a 2wd lenght actuator for a t35 with 2wd manifold though???????????
CossieRich
I know which bit you mean, i'm sure i used my old 1 off my t3 when i put the t34 on my old 2wd. I'm almost possitive its the 2wd lenght 1 i need but would like for someone to confirm before i splash the cash
Originally Posted by GARETH T
Originally Posted by T S M
the difference is -03 lol
Look who's going back to school
saff is working!!!...atm
i use a -31.........t38........30+psi spike....holds 27/28 psi...............do what ever ur tuner says...........not people on a forum.......p.s give stu a ring for ur actuator,always a good price
pete mcrash
I know Pete, i was just wondering the difference tbh, it has a 34 on it already so will be getting replaced with a 34. Stu has 9 available on his evilbay shop for a 2wd so i'm just waiting for someone to tell me its a 2wd 1 i need for my t35 then its getting ordered
i cant be arsed
you need to be arsed mate otherwise how will you get the correct length. Measue the length of the rod will deffo confirm though. It will take you 5 mins tops to do it
