Transmission problem.....HELP.......Update...PROBLEM FOUND
Old May 14, 2007 | 09:26 PM
jake-cos's Avatar
jake-cos
Default Transmission problem.....HELP.......Update...PROBLEM FOUND
Right, quick query.
On the way home from cumbria on sunday my car (4x4 saph cos) developed a nasty vibration/rumble.
Seems to be transmission related, as the gearstick shakes quite badly side to side.
But the vibrations are bad enough to feel right through the seats/peddles!!
Problem is at its worst when accelerating, even smoothly and not decking the throttle (cars only stg1),
Had it on a ramp for a quick look at APs on the way home, no worrying play in either props or drive shafts, no leaks from diffs or gearbox, nothing seems to be loose.......
got us stumped.......
Please someone......put me out my misery and give me a clue!!!!
CheeRS JAKE
Old May 14, 2007 | 09:28 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
could well be a inner cv joint front!
Old May 14, 2007 | 09:31 PM
T28 RST's Avatar
T28 RST
Ok then
O dear
jake-cos's Avatar
jake-cos
We gave all the shafts a good pull/shake and none seemed to have any obvious movement out of the ordinary.....
Could that make the whole car shake like a cunt?
Pardon the language but i'm kinda pissed off with it at the moment!!
Old May 14, 2007 | 09:32 PM
jake-cos's Avatar
jake-cos
Originally Posted by T28 RST
O dear
PMSL.........not exactly the words i've been using since sunday!!!
Old May 14, 2007 | 09:34 PM
JTECH James
Passion for Fords!
yeah it can do! mine did! it sends vibrations through the drivetrain, engine mounts gearbox mount etc
Old May 14, 2007 | 09:36 PM
jake-cos's Avatar
jake-cos
Right o........I'll get it back on a ramp for a look!
TA.
Anyone else?..................
Old May 14, 2007 | 09:41 PM
Big Man's Avatar
Big Man
my saff 4x4 did this- changed prop shaft, driveshafts, cvs etc was a fooking engine mount snaped! Only found it when I took the engine out when it melted No.3
The vibrations were mental....gearstick felt like a machine gun, and the seat was like it was going to explode!!!
Old May 14, 2007 | 09:49 PM
jake-cos's Avatar
jake-cos
I mentioned engine mounts....but it kinda got gradually worse on the journey home, i would of expected engine mounts to just let go in one big bang sort o thing!!??
Worth checkin though...
What about the gearbox mounts?
Could these cause it if they're knackered?
Old May 14, 2007 | 09:57 PM
Big Man's Avatar
Big Man
it started off as a little vibration, it then got so bad i couldnt do more than 30mph. Put it on ramp, open bonnet and jack the engine up and have a look at the mounts, mine was the left hand side (inlet side) and the engine came up 3-4inches! bet its that! esp as ur accelerating the engines twisting/lifting!
Old May 14, 2007 | 10:02 PM
xr4x4rs's Avatar
xr4x4rs
check the propshaft dougnut
these have atendancy to split
my vibration was around 120 though accelerated through it and it snapped my transfer case off
i changed the gearbox mount and doughnut and never had a problem
but id be more than 80% sure the doughnut is split in a couple of places
Old May 14, 2007 | 10:06 PM
jake-cos's Avatar
jake-cos
We had a look when it was on the ramp and it looks pretty fresh, not tired or perished or anything like that.
And couldn't see any obvious splits....
Will have a more thorough check, hopefully tomorrow night!!
Old May 15, 2007 | 06:31 PM
jake-cos's Avatar
jake-cos
BTTT for some fresh ideas......
Old May 15, 2007 | 07:42 PM
CosKev3's Avatar
CosKev3
Changed 3 drivers side shafts on my old 4x4 saph before I checked engine mounts
Put a trolley jack under sump and jacked it up slowly and both mounts were totally fooked
Old May 19, 2007 | 05:40 PM
jake-cos's Avatar
jake-cos
Spot on pal........
Cut tie from inner cv boot......and the joint is fu**ed, bits of loose metal floating around inside!!!
Replacement sourced, just need to get my finger out and change it!
CheeRS for the help boys!!!
bobsworth
77
Mar 24, 2016 09:30 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
rsguy
44
Sep 29, 2015 03:29 PM
SMILER258
Sep 28, 2015 09:04 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
