My S1 was built by monkeys! But corrected by MSD :clap:
Old 13-05-2007 | 05:35 PM
Physio's Avatar
Physio
Default My S1 was built by monkeys! But corrected by MSD :clap:
I bought my S1 a couple of weeks ago & have had a few issues with it to say the least
So firstly the steering wheels was all over the place & i was told that the steering rack had been changed so we thought it might just have been a ball joint or something but it was abit worse than that!!!!
So here's a quick list of faults so far.......
The steering rack didnt have any bushes in the mounts hence the steering wheel turning about 1/2 a turn before actually doing anything
The hub nut was only on finger tight
The car was idling mega high & no matter what i done i couldnt sort it out & then after abit of advice from Stu (MSD) i managed to get the revs down bit it still wasnt running right so Stu told me to take it to him to have a look & get it all set up correctly etc & upon taking the car there this is what we found.........
The car had been bodged to fook & me Stu & Dan couldnt stop pissing ourselves when the car ran WITHOUT any of the boost hoses on
The throttle position sensor was faulty,
The spark plugs were fooked,
The system was pressure tested & had various air leaks,
The cold start injector was fitted WITHOUT a gasket!!
The metering unit air flap was found to be jammed open THIS WAS DONE BY SCREWING A NUT & SELF TAPPING SCREW INTO THE TRAVEL STOP BRIDGE TO STOP THE METERING FLAP FROM RETURNING TO IT'S CORRECT BASE IDLE CONDITION!!
The electro magnetic fuel pressure regulator was wound down excessively causing all sorts of problems & i was told by Stu that this was probably done in a vain attempt to try & get the fueling right,
The fueling was way off the mark,
THE COLD START SENSOR & COOLANT SENSOR WERE CONNECTED BUT TO THE WRONG SENSORS!!
Various wires had been bodged together & live wires were uncovered!!
I cant thank Stu & kenny at MSD enough for sorting out ALL of the above mentioned faults out & also giving it an oil & filter change as the oil was contaminated to fook!
The car drove back from Blackpool a treat, it's running brilliantly & is really nice to drive (it also feels safer as there's no strong smell of fuel anymore)
The moral of this story is - if your buying a car that has been worked on by monkeys walk away
A hugh thanks once again to Stu & Nicole for inviting me to stay over & making me feel welcome in their home
Here are a few pic's of the S1 at MSD
Old 13-05-2007 | 05:37 PM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Good work MSD
Hopefully you're happier with now AJ?
Name and shame the monkeys!!!!
Si
Old 13-05-2007 | 05:39 PM
dave cos4x4's Avatar
dave cos4x4
just goes to show you how bad cars can be.
Old 13-05-2007 | 05:41 PM
The Sludge's Avatar
The Sludge
garibaldi
Thank god for that AJ
Nice to see its all sorted pal. Youll have to lend me the keys for the weekend.............
Love the S1
Stu-top work again then as usual
Old 13-05-2007 | 05:45 PM
Westy's Avatar
Westy
is this the car that Roosie was selling/sold?
Ł1800??? if so, its a cheap car.. No excuse tho with the things that were wrong with it.. but if I paid fook all as above, then a few issues which are not big bucks, then job done..
still seems like a good deal IMO..
Physio's Avatar
Physio
Si yes mate im happy with it now that it's running perfectly
dave cos4x4 yep, it's crappy diy that let's down alot of cars.
the sludge anytime mate
Old 13-05-2007 | 05:47 PM
Physio's Avatar
Physio
Westy yep that's the car i knew there were going to be issues with the car as it was a cheap car but some of the probs were just downright dangerous.
Old 13-05-2007 | 05:52 PM
Ginge !'s Avatar
Ginge !
just finding my feet
is this the series one hes had for a few years, cause if so the plugs on the wrong one would me MY fault as im sure i connected them about 3 years ago
Old 13-05-2007 | 05:54 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Jezuz AJ -Who did you buy it off? - just shows its well worth the drive to blackpool
Old 13-05-2007 | 05:57 PM
Ginge !'s Avatar
Ginge !
will the club is WELL worth the drive imo
Old 13-05-2007 | 05:58 PM
Physio's Avatar
Physio
Ginge ! it's the one in the pics above is that the one you worked on?
RWD_cossie_wil it was well worth the drive to Stu's as the car is running sweet now
Munch's Avatar
Munch
Mr. Sparkle!
glad your happy with it now
Now get some ambers & Spots on there
Old 13-05-2007 | 06:07 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Default Re: My S1 was built by monkeys! But corrected by MSD :clap:
HOW!
How does that happen then
Old 13-05-2007 | 06:10 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
let get my part sorted.
i only had this car for a month if not bit more. i think AJ knows i hadnt done nothing to this car bar fit a new lower arm. i told him about the steering which in the end i give up looking at it.
i hadnt touched the engine part of the bay as i didnt really have it that long or drive it enough.
so before anyone starts saying i left that engine in that state i didnt thats the state i got it in.
no ginge its not the same car that car ended up spot on
the revs went to bad when i had it when i first got it was reving at 1k then when sold it it was about 1200 rpm obvously after a long drive from aj its got worse but thats why there is a post a month back saying "why is my car reving slightly higher"
hope we have this sorted if i knew this aj i would have not sold it or told u either way.
btw the bloke i bought it from was from Norwich dont come on here dont think but well into rs`s he took engine out and sprayed it obvously didint put it back properly.
rant over
GARETH T's Avatar
GARETH T
HOW!
because the metering flap was jammed open i bet
glad you happy AJ,,, i would love an S1 myself
Old 13-05-2007 | 06:15 PM
Ginge !'s Avatar
Ginge !
thank heavens it wasnt down to me thats all i can say
The Sludge's Avatar
The Sludge
garibaldi
Si the sludge anytime mate
Old 13-05-2007 | 06:19 PM
martrs's Avatar
martrs
top guys
Old 13-05-2007 | 06:21 PM
TIFF's Avatar
TIFF
Chasing Radders
Top work Stu
I had to laugh when Stu told me about the selftapper in the metering unit holding the flap open
Old 13-05-2007 | 06:37 PM
fezzajsy's Avatar
fezzajsy
Old 13-05-2007 | 06:38 PM
Physio's Avatar
Physio
Originally Posted by TIFF
Top work Stu
We couldnt fookin believe it mate
Old 13-05-2007 | 06:40 PM
Phil79's Avatar
Phil79
Top notch Stu
AJ you could have rung me you big coooont, I would have popped up for a natter
Old 13-05-2007 | 07:00 PM
Physio's Avatar
Physio
Phil79 soz mate i didnt think of it
Probably as i was fooked by the time i got to Stu's - it took me over 3 hours because of the traffic!!
Old 13-05-2007 | 07:49 PM
Phil79's Avatar
Phil79
You big girl. TBH, not even sure if I still have the same number, lol
PM your way
Old 13-05-2007 | 08:25 PM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
The car was a joke.
Old 13-05-2007 | 08:42 PM
BillyCabrio's Avatar
BillyCabrio
AJ THE PF GOD
Do you want some ambers mate?
Old 13-05-2007 | 08:55 PM
Paul Eggleton's Avatar
Paul Eggleton
Top work Stu
I thought this was the legendary fuel mod
Old 13-05-2007 | 09:14 PM
Turboboy67's Avatar
Turboboy67
What a bodge up, its a wonder it made it to Blackpool
Glad to read its all sorted now though
Now drive it and enjoy it
Cheers.
Old 13-05-2007 | 09:17 PM
timturbo's Avatar
timturbo
where bouts are msd blackpool area?
Old 13-05-2007 | 09:35 PM
Physio's Avatar
Physio
COMEDY DAN you almost had to call the ghostbusters
BillyCabrio yes mate i'd love a set of ambers if you've got a spare pair
Paul Eggleton it was shocking mate
G2.0 RS im enjoying it now as it drives bang on
timturbo MSD are in Bispham mate
Old 13-05-2007 | 09:38 PM
Stu @ M Developments's Avatar
PassionFords Creator
Your very welcome AJ, you know that pal.
Im still giggling at the comment i made...
"Fook me, this thing would probably run without any hoses on, let alone the dump valve or oil filler..." (As it ran fine without those 2, in fact, it ran BETTER!!)
AJ started giggling like a kid and picked up a screwdriver...
How we laughed when it purred!!
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
An RS Turbo running without the top boost pipe on???
Surely not.....
I rang Jay who used to work at Scotties and all he could suggest was a quick call to ghostbusters...
Thank you Jason.
Old 13-05-2007 | 09:39 PM
ECU Monitor Enthusiast
Stu,
How many cushions were on the drivers seat ?
Old 13-05-2007 | 09:48 PM
Physio's Avatar
Physio
Stu mate we should have filmed that like you said
DAN quality reply by your mate
Simon your just a cunt mate
Old 13-05-2007 | 09:49 PM
BillyCabrio
I have indeed mate, make me an offer via PM inc P&P and their yours
Old 13-05-2007 | 09:52 PM
AJ THE PF GOD,
I wanted "SIMON THE PF CUNT" but it wasnt allowed as my name could
be seen as trading (the S in SECS is simon).
(sorry stu - only messing)
Old 13-05-2007 | 09:57 PM
Originally Posted by LS35A
Stu,
Aw man, dont mention teh drivers seat.
Old 13-05-2007 | 09:59 PM
Good times mate, was good to see you.
Old 13-05-2007 | 10:11 PM
4x4 ste's Avatar
4x4 ste
Car looks nice mate , Another top job by msd
Old 13-05-2007 | 10:13 PM
aduz's Avatar
aduz
AJ...stop messing around with that antique for god sake
Quick Reply: My S1 was built by monkeys! But corrected by MSD :clap:
