anbody used extreme motorsport in whitburn?(updated)
#42
Originally Posted by NEIL A
I have used RJM in the past as there local to me and never had problems with there work or service, my car is now at AVA for work but will continue to use RJM for services ect.
#43
T28 RST
you seem to be getting all defensive over the knocking one out over the RR printout
as i said....whats the point in giving a car the torture of the rollers other than to please a customer....have you ever considered that before and after readings can be tweaked by the RR operator? just to please the customer? I.E throttle maybe not be held fully to the floor on first run until they have "set the car up"
like i said dyno sheets are for a certain type of people knocking one out over
i am in no way suggesting this is the case with ava before you all start as i have only heard good things about them
#44
Not getting defensive at al, you seem to be the one getting annoyed when someone says anything against RJM.
Why did they take 7.5 housr to chip my car.
Why did they say i had modded it even more when i took it back.
Why did they give shit customer dervice and say it wasnt there problem.
You seem to know them well enough so you should be able to answer the questions.
#45
if it took 7 hours to chip your car there must have been some other issues you are not telling us about
how can i answer your questions
but can you answer did you knock one out over your RR print out?
i,m off to bed now..see you in the morning ladies
#46
You come on and defend your pals but when your asked some questions about them you dissapear.
There was NO other issues with the car
Seems you dont like me talking about RJM
I didnt knock one out over your RR print out
The way your going on no one should put there car on the rolling road.
#50
Originally Posted by SapphyMike
what was done to the 620Ti?
its standard at the moment, well apart from the new boost gauge and bleed valve, it made 173 atw @9 psi standard on the first run, we opened the bleed valve a bit (11psi), it gained mid range torque bit lost about 5 bhp top end, the third run was aborted due to a slipping clutch....
we only ran it to see what it had before he started work on it, its going to get a ss exhaust made on Monday, it'll be getting a mappable ecu stuck in fairly soon as well. he's also thinking about NOS.
#51
14000+ post superhero
every garage/tuner will have bad stories to tell. ive spent a few thousand quid at rjm over the last few years (mostly on my cossie converted celica)and found them to be decent service (although i did sit for over 2 hours waiting for them to change 2 tyres."were working on it now" etc)they do a thorough job but are a bit to expensive for me to use again. were wanting over Ł950 for a full exhaust system to be made up for my bmw using powerflow stuff im sure they removed their rolling road a while ago.
#53
Originally Posted by dovboy
i use rjm and have had no problems.
they are just over the road from falkland performance ,both these tuners are only a mile or so from my house
#54
#55
rjm. i found falkland to be a bit offhand and snooty in their general manner when getting possible quotes for work to be done so have never used them. clive and roy at rjm have always been helpful and friendly and have never had any shoddy work problems from them but have found them to be just a bit expensive imo.
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
